Operator manual #269
16 pages 3.09MB
Dated 8/16/65
1 page 298KB
Tractor drive belt 6146 replaced by 8005 and both no longer available from Toro - (4L x 72" or 1/2" x 72")
3 pages 116.24KB
1966 model 876- Uses the 5052 hydro transmission identified at Toro as 3100077
1966 serial numbers that have shown up for the 876
173201
174935
175201
175270
192847
192937
192948
192954
193017
193029
193056 - See PSB #073 Nylon clutch pedal bushing changed to bronze after this serial number
193124
