NJ Tom
NJTOM's 701
c-series don
I am a keep it original look when it comes to restoring tractors. However I love that color scheme, it looks great. Hope you can bring it to the big show in June!!!
NJ Tom
Thanks to everyone for all your complimentery comments!  I will take a couple of more pictures this weekend and post them. I have a few from during the build I put up now, one of the engine when I pulled it out and two of the broken cast iron steering support. I was going to weld the old one, even though I hate to weld cast. So, instead I decided to weld up a new one out of steel The rear tires are NanKangs.
Edited by NJ Tom
  • Like 7
  • Excellent 2
cleat
Looks like the old Ford 861 Powermaster that I learned to drive a tractor with.
Loved that old tractor, wish I had bought it when I had the chance.
This is a pic from the internet but ours looked similar.
Cleat
Pullstart
21 hours ago, CasualObserver said:
I really like the aggressive look of those 6-12s... what are they?  Tru-Powers?
I second the tires, they sure do look like they're ready for work!
Great job on the project, I like most everyone else would love to see more pictures of the project!
Pullstart
Well done!
richmondred01
Cleat
They were great tractors. Replacing the clutch was always a challenge to say the least. I had a Golden Jubilee with a FEL I miss the old girl.
Edited by richmondred01
cleat
The one I drove was owned by my grandfather and I believe it was a 1959.
Apparently the clutch went out on it a couple of times but never when I remember.
By that time we had bigger diesel tractors to do the heavy work.
You could pin the clutch pedal in two positions depending on whether you planned on using the PTO or not.
Gear shift was a weird one that slid up and down then front to back to select gears.
Ours had a loader as well but I only actually seen it on once as steering was a bear with it on.
However, the mounting frame stayed on and it had round loops on both sides with a support bar running over the top of the dash.
Lever to raise and lower was on the top of the transmission and it simply had a trip lever for the bucket.
Cleat
Mike'sHorseBarn
Welding and fabricating is something i never learned how to do and boy do i wish i know how. That fix looks excellent!     :handgestures-thumbupleft:
Sarge
Yeah,  nice job on that support,  getting the angle correct isn't easy.
Just a heads up  - when you start a thread, give it a title to describe what you're doing or have a question about. This makes the site run more smoothly and helps when using the search engine results for research or answers to a specific topic. Just a simple title is all that's needed,  otherwise subjects with only a username become too confusing to get answers or comments.
Sarge
WHX??
Yes very deep lugs... brand?
Nakangs sorry I missed that :handgestures-thumbupright:
Edited by WHX14
stevasaurus
Tom, welcome to Red Square.  :handgestures-thumbupright:  I took the liberty of merging your 2 topics because it is a subject still in process.  I also changed the title a little so as to give the members an idea of what they were looking at when they opened your thread.  Your name shows up under the title and choosing a title that explains what the thread is about helps the other members when looking for your topics.  If you would like to change the topic title to something else...please let me know what you would like to change it to and I can do that for you.  Thank you
   BTW...that is a very nice job you did on the 701.  :occasion-xmas:
Buzz
Looks very good. Looks like you're getting hammered with snow today, only 2" in Vineland. What shows do you plan on taking it to?
  • Similar Content
    • Brad Schroder
      By Brad Schroder
      Looking for 701 (k161) parts. Starter/generator, right side belt cover, left side belt cover, air cleaner housing. Thanks
    • oliver2-44
      By oliver2-44
      This one was on Marketplace for quite a while with a hefty price tag.  I ask if he was flexible on price, Nope.  After a quite a while longer same question before I made the drive.  Come on up, maybe we can make a deal.  The rest is history, I didn't steal it, but I'm happy with the deal!
      Ya I know you want pictures, but there a little more interesting back story.  His granddad's business was Nicholson Machine and Equipment and he was a Wheelhorse Dealer in the 50's and 60's in Paris....., Tx  that is!  He sent me this picture of the glass window from the door to the business that he has framed.
      He also wrote me a short note about his Granddad's business.  So after his he passed, his dad gave the tractor to him. he's had it for quite a few years and said it's always been garage kept.
      So if a Dealer owned this for his own use and never sold it, and then it passed to his Son, and then Grandson, that would technically make me the 1st buyer,
        Ok so on to some tractor photo's
      beautiful double pulley belt guard front and center.  It starts with a spray of gas in the carb, but doesn't stay running.
      All there, nice and original, you can see a weld repair on the front of the belt guard,
      Here's the serial number @gwest_ca
      The plastic dash is intact and not cracked!
      My 1st old style split key.
      it still has the orignal Silverton Ags. They hold air, but their so hard they probable don't need any.  I wonder if their hard because they might still have calcium chloride in them???
      The hitch pin isn't frozen and the lift cable even works.
      Interesting decal plastered across the front of the hood.
      aluminum gas tank is fairly clean.
      Hood bottom tab has been repaired.
      topless view of the engine, needs a bath. The front tires are original and hold air, but have some splits across the thread.
      Homemade choke and throttle cable bracket.  The base of the engine has wet oil, so i suspect it needs some gaskets.
      Both axle seals are dry, but the input shaft and brake shaft seals leak.
      I've learned if the top of the transmission is filthy oily, it probable means theirs water in the transmission that has floated the oil out.  This one is clean so hopefully that's a good sign.
      Started some maintenance and a beautiful sight, not a drop of water, just black oil.  It shifts through the gears nicely so it will be interesting to see how it runs/drives.
      I'll gradually go all through it with my checklist.  701 Minor Overhaul Checklist.ods
      Then have to decide if I rub it down with linseed oil like it is, or buff with some steel wool or wet sand to bring a little more red out, then oil.
      How would ya'll put your finishing touches on it?
      I'll update this thread as I do maintenance on it and get it running.
    • wh315-8
      By wh315-8
      So just picked up a 701, obviously the engine isn't right. I have a 7hp Kohler to put on and will put B&S on my Speedex. Anyone ever seen a post come out on the right from the rock shaft? It rotates with the lift handle and has no holes in it. It was done up well, almost looking factory.
    • chompinthebit
      By chompinthebit
      Hi all,
      i bought this 1961 701 in fall of 2018 and restored it. I completed it in fall of 2019 and I wanted to show some pictures of before during and after I got it done. I did my research and tried to make this tractor as close to original as possible. The few exceptions are tires, wiring and the steering support. Not a perfect tractor but sure is nice enough for me.
      all stainless hardware
      Rustolium stops rust Primer
      Rustolium Regal Red enamel paint
      powder coated wheels and seat
      Glenn Pettit Reproduction dash
    • T-Mo
      By T-Mo-(Moderator)
      1961 701s
