D250power
D250
D250power
Hi I am looking for a distributor drive gear for the Renault 800  on the d250.  Also a cylinder head. I lost the gear.
benji756
There is a new posting from a member who just acquired what appears to be a d-250 he may be interested in selling you what you need.
The posting is mystery horse please help
953 nut
:WRS:              Here is the post, perhaps the two of you can work a deal.
D250power
Hi  sounds good what would you want for the parts.
953 nut
Send a PM (personal message to member @Levi, he is the one who has the other "D".
D250power
I am not sure how to maneuver around red square an contact members
953 nut
On the home page at the upper right side you will see an little envelope. Click on it and then click on compose new message, a PM form will come up;  in the "TO" line put in the person you want it to go to, in this case Levi. then fill out the form and send it.
Take a look at this.
http://www.wheelhorseforum.com/forum/56-finding-your-way-around-in-redsquare/
Ed Kennell
Click on the en.....  Dick types faster than me.:)
  • Haha 1
  • Similar Content
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
    • BrianStasC-101
      By BrianStasC-101
