MarkS
C-125 Restoration Project
953 nut
11 hours ago, MarkS said:
I think i am just going to open up the transmission anyway. Not that anything is wrong with it,
I am a charter member of the "IF IT AIN'T BROKE DON'T FIX TI CLUB"! But if you feel you want to dive into it here is a good thread on pulling hubs and one on rebuilding the transaxle.
ohiofarmer
16 hours ago, MarkS said:
Okay, well I just got the back tires off tonight, and am still trying to figure out the best way for me to get the hubs off (I dont curently have any types of pullers):think:. There doesnt seem to be any up and down play in the axle, but its kinda hard for me to tell. I think i am just going to open up the transmission anyway. Not that anything is wrong with it, but I just feel that i would kick myself for not seing the inside of it while I have everything this far apart.
If you do not happen to have an old Wheel horse hub to use as a puller, a Chevy brake rotor may work if you drill out the wheel stud holes a tad.Also, you could just use any brake rotor with a heavy center and drill new holes to suit .  I usually just pick up five six inch grade 5 or grade 8 bolts at TSC. Of course you may think that with only a limited threaded portion that the bolts are not long enough to pull the hub.
 I start out by using a socket to push against the axle and get increasing lengths of socket and socket extensions as i run out of threads.  As you add even and steady pressure to the puller, you can also add some hammer blows[ not necessary to hit it very hard]to the center of the puller to relieve the pressure on the bolts a bit. You can actually hear the steel change tone as you tap the center.
 be creative when you use those sockets. I often nest half inch drive inside 3/4 or one inch drive to get the length of center pusher that I need  When you also use penetrating oil to pull hubs, those hammer taps also make the oil get where it needs to go.
Edited by ohiofarmer
MarkS
Update 9/10/17
I now have most of the parts painted and ready to go back together. Things are starting to look very good. I also have been working to swap out all the bolts for new stainless steel ones. The biggest obstacle yet will be the transmission still. I havent got the hubs of yet to change the axle seals, but I do have a brake rotor that the holes line up perfectly with. Now i just need to get ahold of a pulley puller to pull the hubs off. Should I be concerned with the condition of the gasket between the two sides of the transmission?
More pics from last post
  • Thanks 2
MarkS
  • Like 3
Ed Kennell
I'm not sure why you need a pulley puller to pull the hubs.
If you have the rotor with the correct bolt pattern, just buy a 7/16-20 X 36"  threaded rod and 10 nuts and flat washers.
Cut the rod into 5  7" long studs.  Thread through the hub and lock with a washer and nut on the inside.
Slide the rotor on the studs,  insert spacer on the end of the axle ( a deep socket works well),  install the greased washer and nut on the greased studs.   Pull the hub off by slowly tightening the 5 nuts.    :twocents-02cents:
Painted parts look great.....:text-coolphotos:
Edited by Ed Kennell
MarkS
Haven't posted to this thread in a while, but here is the current state of my C-125. Still need to paint the hood and fender, but its looking good!
  • Like 3
  • Excellent 4
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get a big diesel swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
