Fin_
C-125 Won't Fire
Before it broke it got cross-threaded so we bought a helicoil kit and did that, and it worked fine. Now we found that when we sprayed the fuel starter it seemed to seep out of the helicoil type bush that attaches onto the spark plug.
Did you use high temp RTV as mentioned in the helicoil instructions? I do not know if you can remove a helicoil and put in a new one.  may need to consider a new head.
Guess loctite at this point won't hurt.  Does fuel spur out of the pump out put while you crank?
Edited by pfrederi
I will check if the fuel spurs out tomorrow.
Fuel spurs out of the pump. I started it and it went for a good minute but I had to balance the choke constantly and it was just throwing white smoke out everywhere, you could barely see anything. Also there was some type of liquid running out of the exhaust and carb which I pretty sure was fuel.
Tried again but just turns over and doesn't fire.
You mite want to consider getting somebody to come over and give you a hand.
Edited by Searcher60
  • Similar Content
    • By Joemckna82
      Hi all,
      Looking for an engine for a 1976 A-100.  It's a Briggs # 251707 0161-01 76061512 (I was able to pull parts on Briggs up by using # 251707 0161-99).
      And or a running parts tractor. Complete tractor (and or motor alone) must be in good running condition with no charging or fuel related issues.
      I'm a cash buyer, no BS.
      Thank you!
    • By cabin4me
      I have a 79 C-111 that I pulled a running 11hp briggs and stratton engine from and also a front push blade.  I am looking to sale both.  Push blade 200 Engine 100
      I also have the original mowing deck for this mower.  I am looking for a WH pull behind tiller attachment, maybe trade?
    • By dhr5050
      I am looking for an engine that will easily swap into my C100 that is not the K241AS. Any suggestions?
    • By D250power
      Hi I am looking for a distributor drive gear for the Renault 800  on the d250.  Also a cylinder head. I lost the gear.
    • By Rob R
      Hi folks Brewster Rob here, was gifted a Cub Cadet LTX 1040 in great shape other then a completely blown 19HP in-famous Kohler Courage SV590, today I acquired a 17HP Pro OHV CV490S in perfect running condition.... so I want to swap the engines. They have identical vertical shafts question is the electrical. The Courage had four wires coming from the engine red/green/white/purple, the Pro has 3 white, 1blk and 1 red.  I also have the alternator and regulator from the blown Courage.... might I be able to swap alternators???  I of course have the old Courage key switch I do NOT have the new engine key switch.........  Need help from the Red Square wizards and PLEASE think about the best result way to go here.... thank you in advance.
