JackC
Rebuilding Ark 550 loader cylinders
JackC
I reinstalled the spool valve and adjusted the PTO on the D-200. The PTO adjustment was way off and was not spinning the pump properly to operate the loader. The loader now works perfectly.  The cylinders also hold the position of everything overnight.
Here is the PTO adjustment mechanism and the procedure is in the service manuals. The service manual also recommends and annual cleaning of the PTO.
Texas Todd
Great thread. I am having the same problem with my bucket not staying in the upright position. I have the tilt cylinders off and have the snap rings off.  Is there a trick to getting the piston out? I put the pin back in and tapped with a hammer but its not moving. Thanks for any advice!
82Caddy
Clean the end with the snap ring.  They tend to get crud built on on them.  You can also gently use the piston as a slide hammer.  Slide it in a bit (couple inches) and then pull forcefully out.  Watch out for flying hydraulic fluid/oil.
Texas Todd
Okay. It sure looks like the washer is a bigger circumference than the end of the cylinder, but yet that doesn't make sense! Will give it another go. Thanks!
Texas Todd
Okay, I guess I just wasn't holding my mouth right. Got it out. Is it just these two O-rings? I don't see anything else...
I see one spot where it looks boogered (yellow arrow in the vicinity)
82Caddy
Yep, those two o rings and there is another inside the part with the yellow arrow.  Check the cylinder ram for pitting as well.  It'll tear the o-rings after a few passes over it.
Texas Todd
Found it.
Also found the culprit.
Edited by Texas Todd
Texas Todd
Back in business. Replaced the four o-rings with four of these, as these were the closest I could find. And looked really close.
58dc42979e1b0_ORingsforArkLoaderwithaMetric214oninside.thumb.jpg.0f67ae36db500e0c713dce85b0f70d1b.jpg
Also used a Metric 214 O-ring for inside the piston base, because that's what I had and it was pretty close.
Seemed to work fine. Will see if it holds up over time.
I have some of that hard to lift once the oil gets warm, so I am going to try the PTO adjustment and see if that fixes it.
Thanks guys!
82Caddy
Glad you got it sorted out. Might be worth the time to order/buy enough to do all the cylinders.
Texas Todd
My intention was to get all 8 at least, but the best Hardware store in this area had 4..... But I will get em and have em on hand in the near future.
Like everyone says....its much easier than I suspected.....the great unknown.....
82Caddy
Be sure to check the local hydraulic shops. Those o-rings are pretty generic items. My local FleetPride (formerly CatCo) had all of the o rings I needed in stock and they were cheap. Like sub 5$ to do all 4 cylinders plus have some extras.
Texas Todd
Well, the bucket now holds tilt and lift and doesn't bleed off, but it won't lift any weight. It also won't pick up the front of the tractor unless I "bump" it up. Meaning lift, stop, lift stop. The pump builds pressure and it will lift about an inch and then stop until I let off and wait 1 second or so and bump it again. I noticed the belt was slowing way down when it is under strain. When I let off, the belt spins back up (building pressure) and then after a short bump the belt slows again. It does seem to have more lift power using the tilt cylinders, it will raise the tractor, albeit very slowly using the tilt cylinders but not the lift cylinders without bumping.
The history on this loader was I bought it and the tractor it has always been on and got it mounted back up. I routed the return hose wrong and the pulley sliced it. Replaced the hose with a tractor supply hose and that's when I noticed the tilt bleeding off. The manual called for Type A Power Steering Fluid or No. 5 hydraulic oil. I couldn't find either of those and did some searching on here. Discovered the same model pump and apparently same year (1974) also called for 10w-30 as an option so that's what I replaced after the hose change and tilt cylinder repair.
I am open to suggestions. Bad pump, wrong fluid?
pfrederi
Did you clean out the suction screen??
Pump may not be able to get fluid fast enough
Edited by pfrederi
82Caddy
Belt could be slipping too. Might need to check PTO engagement. Since you switched to motor oil, could need another flush to make sure there isn't any of the old fluid still in it.
Texas Todd
Well, after you try everything....try it once more.  I adjusted the PTO (again) and made it tighter than Dick's hat band and I am back in business! Literally took another couple turns of the turnbuckle to make it work like it should.  I am going to change the oil in it every hour or two of use a couple more times to make sure I just have 10w30 in it.
Man it feels good when you finally get a win!!
Thanks guys!
Is the suction screen on the left side of the pump (driver's side for lack of a better descriptor)? It doesn't have a filter in-line, which may not be a bad idea to install.
pfrederi
the suction screen is actually mounted inside the reservoir (drivers side stanchion) you get to it when you remove the suction hose.  If you mount a filter on the suction line it has to be a special one (basically another coarse screen).  i prefer to use a hydraulic filter on the return/bypass line.  Then you can use 10 micron paper filters.  Consider the hydro system on the tractor itself.  There is a screen filter on the suction line (In the transaxle) and the 1410 spin on filter is on the return side.
Please no comments about my return filter re fittings are what I had lying around and the Fram was the only one the parts store had in stock that day...
Edited by pfrederi
Texas Todd
Awesome. Thank you sir!
  • Similar Content
    • edwroy
      By edwroy
      Needs some help. Purchased an ARK Loader - Model 550 Serial # 573 - anyone know what year this might be?
      Thanks,
      Edwroy
    • boovuc
      By boovuc
      Well the Grange Fair was a short visit!
      Started uninterrupted work on the loader at about 1:30 this afternoon. Finished at 8:20! It was worth it. After some cutting, grinding, filing and minimal cursing because I had no time constraints, I got it on. Thanks to my Karen who slid the tractor under the mount while I held the frame up. (Never made the stands. Used the brace arms to get it off the blocks). No leaks, no seeps, no noises, and full function of everything. Pump is very quiet and barely moves the vacuum gauge on the tractor. Much less work for the motor than my 48 inch mower deck.
      I didn't put the rear weight on so I took it easy and made sure everything was primed in the lines. Plenty of down pressure and fast movement. A big thank you to Malmac, Scott, Wallfish and the others who offered advice and posted pics of their loaders. The biggest pains in putting this on a 520 since it wasn't factory designed for any of the Onan powered tractors was the pump mount and the lever release/lock Attach a matic that is used on the newer tractors and the 1991 520-H. (My 1992 416-8 didn't have the lever design).
      It required cutting out a long skinny triangle from the thick metal original sub frame to allow alignment of the frame holes and shortening the actual lever. (The frame cut took three cutting disks and a good portion of a fourth). I also had some issues with the nut/bolt used on the front mounting bracket. The first frame hole on each side has VERY little room to start a nut. (Because of the gear reduction steering assembly). On the positive end, the factory brace arms leave plenty of clearance around the Onan and hood. My suction line to the pump will need moved since it is in harms way. I think the pump is OK where it is at with a guard to be made soon. I'll work it harder on Monday and really heat the oil up and check again for leaks or seeps again. I do have to weld a wallowed loader lift cylinder pin hole but even it isn't too bad. The others are real tight. Not bad for as old as it is and for 500 bucks.
      This was always a real want for me so please excuse my over exuberance. This makes the beginning of the work week a joy! It might take until noon at work tomorrow to wipe this grin off my face!
    • chevyaddict83
      By chevyaddict83
      So, i ended up rebuilding curl pistons, worked great. Now, having lift issues. If i pull on the lift lever slightly, i still get the arms to go up. If i pull all the way back, the whole thing drops. If i leave it raised and fill the bucket, it stays up and dumps fine. Is it something in the control valve? Maybe an adjustment?
      Sent from my LG-LS980 using Tapatalk
    • prondzy
      By prondzy
      So i have an ark 508 loader on my c160. I was wondering if any of the other Ark FEL owners could tell me if there is a "float" postion in the spool valve?
    • bo dawg
      By bo dawg
      Is it hard to pull apart to replace seals? Any tricks? Or things to watch for?
