elicountryboy1996
wheel horse bushing
elicountryboy1996
I have a wheel horse c-161 automatic hydro, And I was plowing with it, there is a small bar under the seat that swings back and forth with the hydraulics and it is attached to a circular piece with 2 bushings that have a small flange on the end of them, they are both pretty much shot and the one flange broke off so I could no longer raise my plow because the piece holding the bar with the bushings popped out because the one bushing is completely shot, Anybody Know where I can get these small bushings?
oldredrider
I think he's referring to the bushings in the rear rock shaft. If not available from Partstree,  you might try your local Ace hardware.
Ed Kennell
:text-yeahthat: Pretty sure ACE and TSC have the flanged bronze bushings.   3/4 X 1" sounds  familiar  but check your shaft and holes.
elicountryboy1996
It is indeed the clevis hitch and I was able to get the bushing/bearing pieces at ACE hardware, they arent factory but they get the job done, thanks for all your help guys
Ed Kennell
What is the current ACE price?    I think they have a slightly thicker flange than the TORO part.
BTW,  :text-welcomeconfetti: to :rs:        Good to hear from another PeeeeAaaaer.
Edited by Ed Kennell
elicountryboy1996
I payed like 7 Bucks for 2
ol550
Check the vender section. Wheelhorseman1000 has them on his site.
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
