Stilly
Tecumseh exhaust
Stilly
Just bought lawn ranger no exhaust.   6 hp Tecumseh motor.   Is exhaust thread 3/4 black pipe?    Would like to run two elbows from block and have muffler face up.   Will I need to brace??
the Lawn Ranger had a brace on the exhaust , and  i'd certainly recommend  using one
sorekiwi
I dont remember the size of the threads in the block and dont have one handy to look at.
Yes run a brace, I have seen 2 Tecumseh blocks that have cracked into the exhaust port because of not running one.
callum12
I've got a stack o my tractor, definitely brace it, I've got mine braced at two points you can almost lift the tractors front end off the ground with it! all it would take is a branch  or someone bashing into it to crack the block.
stacks are nice though, makes the tractor sound much nicer i think :)
callum
Sprocket
What type of muffler are you using?  I don't want a stack but would like something quieter.
Back in high school a buddy did his RJ58 with a nice set up - I just can't remember what he used...
callum12
don't be fooled! my stack is pretty quite, so much so you can hear the slight tap of the valves (in person), or are you just not into the whole stack look?  the muffler I've got is a stainless steel 1.5", the type with the perforated tube inside. i think what also helps with mine is that it from the outlet the is a 180 degree twist followed by a 90 degree bends before it goes into the stack you can also get baffles that slip inside the exhaust.  you can also see it is quite tall which also helps somewhat.
heres a pic:
11212231_1639378732962316_304412075_n_zp
11139831_1626327754267414_2087720320_n_z
here is a video from my youtube channel. it is as loud as it appears in the video really:
hope this helps, don't rule out stacks, they are very simple to build and sound loads better than a pepper pot type exhaust (in my opinion that is :) )
callum
slammer302
Stilly
This is my setup.  Harley muffler cut down both ends using muffler like slammer screwed down holding in place.  Wish I would have left more pipe on top.  Sounds great.  Fumes are bit of a problem when starting.  How do I post picture trying copy paste does work.
Edited by Stilly
callum12
to post a pic i used photo bucket, you upload the picture to there then they give you a URL to copy and paste. when you post you message the picture will be there. there is also the add media button just above the submit reply button, never used this feature for pics though, only youtube videos.
fumes aren't a problem for me, my stack is tall enough and i think the rain cap helps to deflect it all.
Callum
  • Similar Content
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
    • BrianStasC-101
      By BrianStasC-101
