zanepetty
leaky rearend pulley
stevasaurus
That TORO dealer has no clue on how to do a 5025 transmission.  Don't you let him touch it!!!  They come apart easy and go back together easier.  Time for us to ask you some questions. :)  Tools...got a 9/16 box end wrench and an assortment of sockets and a ratchet?  Do you have a razor knife?  Do you have a scraper?  Do you have some punches and a ball peen hammer?  How about some hand cleaner and some rags or paper towels?  Sorry...I got to ask this...how old are you?  Just curious. :)  If you decide to tackle this, and I think you should, we all will help walk you through the process.  Check out these threads and watch the videos... :eusa-think:
This thread show tons of pictures and is the same transmission that you have.
pfrederi
Think I would find another dealer.
If you have the hubs off you are 2/3 the way home.  Is pin that holds the hitch on free...move side to side and/or twist it?
zanepetty
What about the hitch pfrederi? I do have the hubs off!
953 nut
:text-goodpost:   The toughest task when pulling apart a :wh:  trans. seems to be removing the hubs that your rear wheels bolt onto. Whatever you do, don't try to hammer them off; either you will bust them or the lock ring retainer on the inside will break, both are bad things! :text-lol:
At the rear of your trans. you will have a 3/4" pin that goes through the two halves of the trans. and attaches your trailer hitch and/or slot hitch, remove the lock rings and drive it out with a punch ( this you can hit!)
Once you have watched the vidios anr read a few postings on this site you should have no problem doing the job.
Let us know how you are doing.
:USA:
zanepetty
Well I've got the hubs off so I must be doing OK! Haha
stevasaurus
If you get that hitch pin out...you are home free.  The hardest part is done.  Run the seam with a razor knife between the 2 halves after you take out the bolts...make sure you have the shallow side of the trans down and the shifter out...you are just cutting the paint...find a good edge between the castings and use a good sharp chisel or scraper to break loose the trans halves...separate evenly...use a pry bar or two at different spots...the factory did not use gasket sealer, and we will not use it to put it back together, you can pry it up easily after that.  Did I say that it is a great idea to file the ends of all shafts...ie...file all burrs...so there is no hold up pulling the two halves of the trans apart??  Use your hand to feel the ends of the shafts for high parts or burrs...file them smooth first before trying to take the trans half apart.  :) It is soft metal and does not take much, but worth the time when you put it back together....plus saving seals.
Edited by stevasaurus
zanepetty
OK. I'll do that. I was VERY down when I found out the seals weren't my problem but you've convinced me I can do it! Like I said I'll tear into it tomorrow afternoon and I'll give you a call when I go to the barn Mr. Steve.will the new bearings also take care of the in/out motion of the axle?
stevasaurus
No, new bearings will not take care of in and out...just up and down and side to side.  In and out play to about 1/8" or a little more is normal...you will see why when you take it apart.  Just relax for a bit, watch the sun go down and call me tomorrow. :)  Talk with your horse, give it a carrot and a lump of sugar...this is out patient surgery.  It will be OK.
rmaynard
If you haven't already done so, don't forget to drain the transmission oil before attempting to open her up.
zanepetty
Hana OK I will! Thanks guys.
Lagersolut
This is actually very close to how I installed my seals. But unfortunately I do have a little bit of up and down motion. So I guess I'll need to open it up. I've never done something like this so I don't know if its a job I can do or one I should try to get a toro dealer to do..?
Don't worry - ( don't listen to that Toro dealer either ) Steve and these guys will get you through this - I rebuilt an 8 speed earlier this year and knew  zero about doing a trans ...I was afraid of not getting it back together as well....these guys won't steer you wrong .
zanepetty
I've read a lot of posts that these guys have written and they are SHARP. I'm just glad they're around!
stevasaurus
Zane, it was a pleasure talking with you today.  Here are the numbers for what you are going to fix at the moment...if you do not find anything else worn.
Transmission gasket...from TORO...WH # 3912...about $6.00
Outer axle bearings (2)...from Motion Industries...torrington # B-1616...just over $6.00 apiece
Axle seals (2) and brake shaft seal (1)...from Motion Industries...SKF 9815...just under $3.00 each
Input shaft seal (1)...from Motion Industries...SKF 7410...about $3.50
A neat trick for when you put the transmission back on to the frame of the tractor. Take (2)  3/8" x 2" hex head bolts and cut the heads off.  Hand screw them in to the transmission mounting holes...bottom on one side and top on the other.  Use this to line up the transmission on to the frame...(as studs).  Start and snug up the other 2 bolts...remove the studs and place the two bolts that are left.  This makes mounting the transmission back on the frame a piece of cake. :)  You can use one of your rear wheels to hold the trans while working on it if you want.
2012_0903blower0001_zps789c2112.jpg[/url
zanepetty
It was a pleasure talking to you as well, steve! Looks like my axles are not the same diameter all the way out. They have wear on them:(
stevasaurus
It depends where and how much wear you have.  Is it worn where the outer bearing sits...grooves???  How about where the seal would be??  A little may be OK, once you replace those bad outer bearings.  Are there any grooves in the axles where that outer bearing sits??
zanepetty
Well the wear is just a bit behind the key way slot and im pretty sure that where the seals would be its OK. But I'll have to double check. I want to do it right. Maybe loose hubs may have caused it?
stevasaurus
They sound like they would be OK if there are no grooves.  Those axles are 60 years old...a little wear is to be expected...and the the seal will still work with the new axle bearings.  Your Photobucket link is not working...try copy and pasting with the IMG code under your pictures that you are trying to post. :)  Yes, absolutely , want to do it right while you have it apart.  What do you think...glad you did not let the TORO guy do it??? :bow-blue:
zanepetty
HAHA YES!! SO GLAD! I just don't see and image code at all. I don't know what my problem is with this darn thing.
zanepetty
Lagersolut
Zane  - if you can get your pics on your computer desktop/my pictures  use this link - it has a drop down list for resize - pick forums ( you'll need to do a capatcha code on upload ) upload them from your computer desktop to tiny -pic - a list of links will appear after it uploads,  copy and past the forum IMG code link right to your reply page here ....
Much easier than photo bucket
http://tinypic.com/
Edited by Golds-Red
zanepetty
I'm trying to do it from my phone but I'm not having any luck so far
stevasaurus
here is all the numbers for the bearings and seals for your #5025 transmission.
Here is a list of the bearing and seal numbers...This works for 5007, 5025, 5046, 5048, 5049, 5033 3 speed uni-drives.
Description.....................................WH #...................Vender #..................Quantity.......size
in side axle...ball...........................1533.......................n/a...........................2................1 1/2" ID
out side axle...needle....................1528......................B-1616.....................2................1' x 1 1/4" x 1"
input shaft...needle........................1508......................B-1212.....................2................3/4" x 15/16" x 3/4"
11/44 gear base...needle...cap......1532......................M-16121..................1.................1" x 1 1/4" x 3/4"
brake shaft top end...needle..........1530......................B-1612.....................1.................1" x 1 1/4" x 3/4"
cluster gear shaft...needle...cap....1529......................M-12121...................2................3/4" x 15/16" x 3/4"
input spline shaft...needle...cap.....1531......................M-10121...................1................5/8" x 7/8" x 3/4"
inside input gear shaft...needle......1518.....................B-108........................1................5/8" x 15/16" x 1/2"
input gear seal...............................1303.....................skf-7410....................1
axle & brake shaft seals................1232.....................skf-9815...................3
zanepetty
OK cool. And those are for motor industries?
Lagersolut
Motion Industries
Here are the locations in Tennessee
http://www.motionindustries.com/motion3/jsp/mii/LocationsMI.jsp
The numbers to the left ( most are 15_ _ ) are the Toro/Wheelhorse part #'s  the ones  on the right are the Koyo Torrington   part  #'s
Toro parts are way more expensive for the bearings and seals you need - I didn't buy mine through Motion but I did go with the Torringtons by putting a one time big over $25 " FREE " shipping order on Amazon .
The 1533 bearing at the top isn't  available through anyone ( they're no longer made ) however I did read some posts here where a few guys may have some  if you find a bad one - even if your 1533's are good ...while your in there clean any rust or blemishes off of them and flush them good to get all the dirt and metal particles out - I used brake cleaner from the auto parts store -
From Steves earlier post - numbers you need for motion
Bryan
Edited by Golds-Red
  • Similar Content
    • giant_g2
      By giant_g2
    • jmack
      By jmack
      I’m looking for a transmission dipstick to a D-180. Let me know if you see one.
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
