FZR
Routing Diagram for an LT-1100 3-Speed Drive Belt
Does anyone know where I can get a Routing Diagram for an LT-1100 3-Speed Drive Belt.  I'm looking for the routing diagram for the drive belt that runs from the engine to the transmission.  Any help would be appreciated.
You can download the tractor operator manual from the files of this forum. Open the manuals section and do a search for 810342R1. It is posted in 9 parts.
Nothing on belt replacement in it but the brake adjustment is described.
Garry
Thank you Dave.  I think that diagram should help quite a bit.
Garry, thank you for the directions to the manual.  That should be useful, too.
  • Similar Content
    • By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: https://www.dropbox.com/s/zp8ty4oxctzvt8a/Wheel Horse Hydro Foot Pedal Instructions V3.pdf?dl=0
      I am selling these kits for $250 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • By hunterguy92
      Greetings everyone-
      After draining the old molasses out of my transmission, quickly flushing with diesel and refilling with 85-W140 my left rear axle and input shaft seal drip a little each day.
      Thanks to this forum I found the seals I need at Napa, but am a little nervous pulling off the input shaft pulley without damaging the pulley itself. Any advice/write-ups on this?
      This photo is as I bought the tractor. Am I missing a bolt and washer?
      Thanks for the help guys!
    • By JP56
      I purchased what I was told by the seller, to be a "partially restored" 1975 C Series. I have it now for 3 seasons & have concluded that this restoration consisted of replacing a few bolts and repainting it and replacing some of the decals. The seller told me he "screwed up" on the Model Decals when he ordered them, & put the wrong one on it (C120), but did not tell me the correct one that should be on it, and he gave me a 1975 C Series Owners Manual with it. I am wondering if the Model Numbers correlate to the horsepower of the engines. If that is the case, I must have a C100, because mine has the Kohler 10 HP engine, which is labeled as a K241S. It has an 8 Speed Manual Transmission.
      After getting it home and using it, I put it in my shed & the next time I went to use it, I see the transmission/gearbox has leaked oil onto the shed floor, appears to be coming from the seam between the two halves of the rear-end. I also see a heavy black greasy film build up at both axle seals & also around the brake drum seal. I am now in doubt of the recommended oil for the rear end. Some of the online forums say that they had begun using transmission fluid as a replacement for older types of lubes, while others say 10-30 motor oil. I saw someplace which I can't seem to find again right now, that 85W-140 gear lube was what should be used. The oil level on the dipstick has not dropped to low levels, and appears to be motor oil, so after searching around and also checking the manual given to me with the tractor, I top off the level with 10W-30 as spec'd on page 5 of the manual(if this is indeed the right manual for my year and model).
      My problem now, is that last season, it suddenly seemed to get a bit sluggish & slow down as it gets warmer during use. I believe my sluggishness problem might be due to the leak in the box seam and possibly also the type of fluid/lube in the case of the transmission/gearbox. I had already tweaked the carb as best I could, changed the fuel filter, replaced the spark plug due to a hard starting condition and rough running, & it seems to be running fine right now except for a backfire when shutting it down. I have purchased a replacement carb for it that I have to put on now, & I am pretty sure I need to locate & change the points as well.
      Anyway I am hoping that someone can point me towards the right manuals, by placing all numbers I have been able to find on it here so I can hopefully find the right service/repair manuals (hopefully as free downloads someplace online) for the different systems.
      Tractor:
      Model: 103909
      Serial Number: 47404
      Engine:
      Model: K241S
      Specs: 46636D
      S/N: 6097616
      Deck: 0542M505
      All Numbers on Transmission/Gearbox Casting:
      A24
      8163 or B163 ?(Cannot Read Clearly)
      101761 or 1017G1 ?(Cannot Read Clearly)
      Any and all advice/info anyone can supply me with on this would be greatly appreciated! Also, any tips on good places to purchase reasonably priced parts would be good as well.
    • By Seacrestbf
      Hello
      When we try to push the machine with out it running or in gear. The rear wheels are locking up. Is there a release valve? I have to push it from the storage area to the shop, the motor is rapping.
      Thank you
    • By Goldann520
      Well guys, I guess it's so long! Someone bought my JD 212 yesterday,  and couldn't refuse the money for my 520 today.😣 I am no longer a wh owner, so doesnt feel right hangin' out with you guys. Thanks Terry  good luck all. See you down the road.
