"In the end, we will remember not the words of our enemies, but the silence of our friends." – Martin Luther King, Jr.
wheeledhorseman
PTO clutch plate lining
19 posts in this topic
I need to replace the friction lining on the PTO of my C-100.
Can anyone tell me the original thickness of the lining when new?
I'm thinking of just bonding the new lining to the plate with epoxy rather than using rivets - is that ok?
Thanks
Andy
Andy,
I bonded one with JB Weld. Worked fine. I will check the thickness of a new clutch facing for you tomorrow and post it for you.
Marvin
I just rebuilt my pto.
Matt
Where did you get the friction material?
Why not buy a new clutch facing (PN 4365) and (6) new rivets (PN 6657) from Toro?...they are still available.
You might want to check the diameter of both PTO "bells"...I think the clutch facing w/rivet holes is smaller that the bonded facing?
What year did they quit using the small bells, will they work well on a C series tractor ??
Chas
I bonded my last one, didn't completly trust it so I put I think four equally
spaced rivets. Worked fine and purchased it at my local bearing supply of all places.
they just had many different sizes, havent got a clue what for and it only cost me I think about six bucks
about five years ago. Shortly after that I was in a huge John Deere dealer and they had about a bazillion
clutch facings for whatever, so Deere must have a bunch of stuff with about the same facings.
Food for thought JIM in Texas
Say Bowtie, the replacement plate in the picture contacts the machined surface on my bell perfectly, but the original only contacted about 2/3's of the surface area. The new plate pictured is a toro replacement, I just think its an improved design with more holding power. :twocents-02cents:
Matt
HELLO GUYS, I JUST PUT A DISC ON A SPARE PLATE TODAY. I USED A 2 PART STRUCTURAL ADHESIVE AND CLAMPED IT. TOMORROW I WILL CHECK IT AND WILL ADD HOLLOW STEELL RIVITS. I WILL USE A DREMEL SANDING STONE IN A DRILL PRESS TO BORE THE DISC MATERIAL. THE RIVITS NEED TO BE COUNTER SUNK IN THE DISC MATERIAL. MY DISC MATERIAL IS .125 THICK AND I PLAN ON COUNTER SINKING AROUND .050-.060 DEEP. THIS IS MY FIRST ATTEMPT. I HAVE ONE SPARE DISC MATERIAL AND RIVITS IF ANYBODY IS INTERESTED. THANKS
BOWTIE IN OHIO
Andy,
I measured the clutch facing and it is .120 thick. This one is a new facing that uses rivets. The one I bonded originally had rivets.
Marvin
Thanks for that Marv :handgestures-thumbup:.
Being as everything is metric here in the UK I make that to be 3mm, just need to source some lining material next.
Good job I asked as I'd have guessed thicker than that - it appears that there was never much 'meat' on these from new.
That's useful information Frank :handgestures-thumbup: - slight issue in the UK is that you can order parts from Toro here but $ converts to £ on a one for one basis :angry: and if there's no stock in the UK you can wait weeks for the next shipment to arrive. :confusion-waiting:
I think I'll just bond the facing and use the PTO assembly itself to apply the necessary pressure - making sure of course that I dont get any adhesive on the wrong side! I think pretty much all automobile type applications use bonded linings these days.
Andy
I would tell you if I was at my shop, but I think Marvin has got you covered. I just rebiult my pto.
Matt
Check the thickness of the metal new plate, if it's not the same as the old one it will ware out the c-clips. Got one from Toro that was thinner had to put a thin shim behind the plate to fix it.
Have a Wheelhorse model #101208 s/n 963320, 8hp Kohler, 4 speed.  Need part number for PTO clutch lining.  My diameter is 5".
I don't believe that the lining is still available for your 1973 8HP 4 Speed, but the entire clutch plate #6655 is. You might want to check eBay. Quite often a lining shows up there.
  • Excellent 1
This post might be helpful.
Pto clutch plate for a baler works just grind the center out to fit and about 20$ it's a bit thicker than the other but it's been good for Wheelhorse  guy bedford indiana!
  • Similar Content
    • By Sarge
      Has anyone found a fuel gauge type cap to fit the 2-1/4" threaded neck on the plastic tanks in the C-series? My current cap leaks at much over 3/4 tank, would love to get a better-sealed unit with a gauge on it. I did find a Kelch to fit the D, it's a bit short but works great and doesn't leak, while still vented correctly.
      Sarge
    • By Gary L. Wood
      Guess I don’t understand what you mean by title and tags?
    • By skippy1969
      I'm selling my 1975 C160 Automatic because I'm moving in a different direction.
      It is in nice used condition and runs excellent and the hydro is strong.
      The original K341 runs great, starts easy no Kohler death rattle.
      It does smoke for a second or two when cold. But It doesn't appear to burn any oil between changes.
      I have a big list of new items I installed.
      All 4 tie rods and connecting rods from WheelHorseman 1000
      All 4 brand new original style Carlisle Turf Saver tires rear upgraded from 23X8.50X12 to 23X9.50X12.
      New battery,
      New belts+Idler pulley.
      New aftermarket analog hour meter.
      New OEM mule drive knob.
      OEM Mower clutch pin.
      NOS Hydro lever cover "Rare"!!!
      New aftermarket seat.
      New OEM headlight lens with LED headlights.
      New Wheelhorseman1000 rear plow mount.
      New OEM INDAK ignition switch.
      New starter.
      Recent tunes up genuine Kohler points and condenser.
      New Ignition coil.
      This tractor comes with a newer model 42" mower deck "See pictures" it mows great!
      42" snow blade included with new Wheelhorseman1000 rear mount an a newer set of tire chains. I can subtract $150.00 if you don't want/need the plow and chains.
      Wheel weights shown are NOT included or available for sale, sorry.
      Asking $950.00 O.B.O.
      Pick up in Baraboo Wisconsin 53913.
      I might be able to meet up within 100 miles for gas money.
      Any questions,don't hesitate to ask.
    • By dmhill
      Hello all,
      Am in search of parts for my latest adventure. I am looking for the rear axle bracket and lift arm for a plow. Also in desperate need of the lift arm for the mowing deck (maybe same as lift arm for plow?). The previous owner just put a chain between the lift pivot and the connection on the deck.
      Any assistance would be appreciated.
      Darren
Premium Theme Designed By IBTheme.com
