Heatingman 977 #1 Posted September 7, 2022 Ive read many times @peter lena talk of swapping out the grease in the needle bearing. Thats easy enough, but what about the ball bearing the PTO lever linage attaches to? Looks like a well fit rubber shield over the balls. Dont want to damage it trying to keep it going another 50 years. 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #2 Posted September 7, 2022 Those seals are generally quite easy to remove. Get a small screwdriver under the lip and gently lift it out. There's a thin metal shim as part of the seal, try not to bend it. Easily flattened if you do. 2 2 Share this post Link to post Share on other sites
squonk 46,072 #3 Posted September 7, 2022 Some of those bearings I've run across are steel shielded. Napa PP204RR6 $6.50. Almost not worth destroying the shields just to grease it 2 1 Share this post Link to post Share on other sites
peter lena 9,846 #4 Posted September 7, 2022 @Heatingman agree with @Jeff-C175 on the easy seal removal , use a flat pocket screwdriver , carefully get it started , once it starts , you are good . the existing generic lubrication , is the problem , in both related bearings , the inner needle bearing also , needs a wipe out , and a smaller amount of hi temp grease to prevent slinging onto clutch facing . lucas 560 deg , anti sling polyurea rated chassis grease , is the deal . BTW when ever I get ANY bearing , the first thing I look at is the side seal access , so I can easily , do the grease change / upgrade . EVERY RELATED BEARING , in my pto lever drive to mule drive to mower deck spindles has the grease change over , how easily do you think that set up works ? I don't continuously mention this upgrade , just to have an argument , but you know what fails , this is the fix, used it for years , my 3 horses have the same reliable upgrade , lots of hours , and silent bearings , you are right there in the opportunity stage , why not do it ? pete 1 1 Share this post Link to post Share on other sites
lynnmor 8,736 #5 Posted September 7, 2022 1 hour ago, squonk said: Some of those bearings I've run across are steel shielded. Napa PP204RR6 $6.50. Almost not worth destroying the shields just to grease it I don't fool with them, at the price it ain't worth it. The only time I ever replaced those bearings is when I refaced the clutch surface. That size bearing is available in rubber or metal shields. 2 2 Share this post Link to post Share on other sites
Heatingman 977 #6 Posted September 7, 2022 (edited) Was able to add grease with a little dental type pick without removing the shield. Tried working the shield off, its just on there too good. Felt like it would tear, so I called it good. Edited September 7, 2022 by Heatingman 2 Share this post Link to post Share on other sites
kpinnc 17,768 #7 Posted September 9, 2022 This may bring out a few comments- but I usually remove the seal on the inside of the small bearing and leave it out. When I grease the large needle bearing, I push fresh grease into the smaller bearing as well. Just my opinion... Your results may vary. 1 Share this post Link to post Share on other sites
Rick3478 445 #8 Posted September 9, 2022 2 hours ago, kpinnc said: This may bring out a few comments- but I usually remove the seal on the inside of the small bearing and leave it out. When I grease the large needle bearing, I push fresh grease into the smaller bearing as well. Just my opinion... Your results may vary. Won't centrifugal force spin the grease out of the bearing if you do that? 1 Share this post Link to post Share on other sites
peter lena 9,846 #9 Posted September 9, 2022 @Heatingman whenever I buy a bearing , first thing I look for is a rubber shield , my pocket flat screwdriver , makes short work of the seal , without damage . every one of my bearings has been redone , another thing I regularly read is pto clutch units , being replaced , with the lube set up I use , there is no struggle or screaming engagement , is that telling you something about belt drive drag on related bearing rotation ? have not replaced my clutches . don,t understand all the related issues , not having any drive drag , on pto lever , just smooth easy , quiet engagement . planning on lubing the inner needle bearing ? how about mule drive bearings ? they are cake for easy removal , clean out / regrease , replace . lots of hours , no bearing noise , going to be selling some stuff , blower, plow, mower deck , weights , like new auger , all been touched with improvements , very scary , pete 1 Share this post Link to post Share on other sites
lynnmor 8,736 #10 Posted September 9, 2022 3 hours ago, kpinnc said: This may bring out a few comments- but I usually remove the seal on the inside of the small bearing and leave it out. When I grease the large needle bearing, I push fresh grease into the smaller bearing as well. Just my opinion... Your results may vary. I use a high temperature synthetic grease in the large needle bearing, I am sure that it is not compatible with what is in the sealed bearing. 1 Share this post Link to post Share on other sites
Heatingman 977 #11 Posted September 9, 2022 1 hour ago, peter lena said: @Heatingman whenever I buy a bearing , first thing I look for is a rubber shield , my pocket flat screwdriver , makes short work of the seal , without damage . every one of my bearings has been redone , another thing I regularly read is pto clutch units , being replaced , with the lube set up I use , there is no struggle or screaming engagement , is that telling you something about belt drive drag on related bearing rotation ? have not replaced my clutches . don,t understand all the related issues , not having any drive drag , on pto lever , just smooth easy , quiet engagement . planning on lubing the inner needle bearing ? how about mule drive bearings ? they are cake for easy removal , clean out / regrease , replace . lots of hours , no bearing noise , going to be selling some stuff , blower, plow, mower deck , weights , like new auger , all been touched with improvements , very scary , pete I was able to remove the sheilds and regrease everything else - mule drive, etc… but not this particular bearing. The rubber shield is not just a flat rubber over steel. This one is form fit rubber with an integral dust seal at the shaft point. 2 Share this post Link to post Share on other sites
