Forrest Carver 52 #1 Posted August 31, 2022 (edited) Got a 1975 D160 a few weeks ago and it has been a labor of love working out the kinks and learning about the machine. Thank you all for the help thus far! I'm going to relegate all my issues to this one thread to avoid excessive posting. If anyone has any ideas or suggestions on the below problems, please let me know. I can provide pics and/or videos if that's helpful. Current Issues: Problem: Significant speed difference going uphill vs on flats Cause: Hydro pump/motor is worn, slippers and valve plates have been scratched/gouged by metal bits passing through the system (thanks pfrederi!) Solution: resurface valve plates and slippers Problem: Low/intermittent power at PTO Cause #1: Clutch plate? Solution: ? Cause #2: Slipping belt? Solution: Investigated belt. Looks good visually, doesn’t sound good. Like an old screen door opening. Cause #3: ? Solution: ? Problem: 25a fuse blows when headlights switched on Cause: ? Solution: ? or ignore Problem: Excessive condensation in gauges Cause: ? Solution: ? or ignore Problem: No brakes Cause: Missing brake band assembly Solution: Replace brake band assembly or use wheel chocks Problem: Wicked easy to pop a wheelie Cause: Tiller and rear wheel weights installed concurrently Solution: Obtain/fabricate and install front wheel weights, or remove rear wheel weights Problem: Loose speed control handle Cause: Just a little worn out Solution: Replace or ignore Problem: Floods occasionally Cause #1: Debris in gas Solution: Will eventually flush tank, replace fuel lines, and clean carb bowl Cause #2: ? Solution: ? Problem: Tractor is too small and weak for my needs and acreage Cause: Cat 0 3pt hitch, not enough HP for necessary attachments Solution: Borrow dad's mid-70s Kubota L-series indefinitely Problem: Love this tractor too much to get rid of it Cause: it's awesome Solution: Let my sister borrow the D160 indefinitely, or just keep it like a toy/collectible Past Issues: Problem: Blowing 25a fuses Cause #1: Faulty ammeter Solution: Bypassed Cause #2: Poor routing, wires melted and grounded Solution: Replaced wires and routed them properly Problem: Throttle reverts to mid-throttle from full throttle Cause: Loose friction bolt Solution: Tightened friction bolt slightly Problem: Insufficient room for knees Cause: Seat position wrong for me Solution: Installed lifter blocks Problem: Headlights not functional Cause: Severed wire Solution: Reconnected wire Problem: Rattling dashboard Cause: Located missing 5/16 mounting bolt Solution: Replaced bolt Edited September 2, 2022 by Forrest Carver Share this post Link to post Share on other sites
pfrederi 19,278 #2 Posted September 1, 2022 Speed variance uphill vs flat Cause hydro pump/motor is worn, slippers and valve plates have been scratched/gouged by metal bits passing through the system. Fix. open her up resurface valve plates and slippers.... Major project. Share this post Link to post Share on other sites
Forrest Carver 52 #3 Posted September 1, 2022 5 hours ago, pfrederi said: Speed variance uphill vs flat Cause hydro pump/motor is worn, slippers and valve plates have been scratched/gouged by metal bits passing through the system. Fix. open her up resurface valve plates and slippers.... Major project. Thanks. Is this a problem I can safely ignore for a while/forever? Share this post Link to post Share on other sites
ineedanother 1,814 #4 Posted September 1, 2022 4 hours ago, Forrest Carver said: Thanks. Is this a problem I can safely ignore for a while/forever? I don't know the d-160s well but not all had the external brake band and I gather yours should. With that and a functional brake pawl for parking, you can probably kick that can down the road a bit unless it gets too bad or you are working on a lot of grade where you might really need to have the hydro controlling your speed better. Share this post Link to post Share on other sites
pacer 3,177 #5 Posted September 2, 2022 Ahhh! The --- famous/INfamous 'Big D's' Sort of a love/hate thing with them here on the forum. As it so happens I am a pretty big fan of them (I'm down to 3 at the moment). so, I can tell you right up front that you are gonna need to get up close and personal with the beast. They have pecularities that are unlike any other of the horses, so will need to start the process of learning some of them. The problem @pfrederi refers to is one of the 'biggies' and "Major project" is very true. As to ignoring it ... yes you can, and, it may go for a good while..... but, you will be wearing these components to the point where they cant be 'brought back to life'. If you are a pretty decent 'shadetree mechanic' then you should be able to tackle it, its not terribly complicated, just a good bit of work. There is more than enough info here on the forum to walk you through it. Plus, there is - thankfully - still a pretty good source of parts available (I have a couple of the motors, and ... maybe a pump?) Share this post Link to post Share on other sites
Forrest Carver 52 #6 Posted September 2, 2022 Thanks! So if I understand correctly, using the speed lever as a brake is likely exacerbating the wear on the hydro pump/motor, so I will likely be able to get more time out of it if I get a brake hooked up and use that instead of the speed control lever? Yesterday I hooked up the snow/dozer blade to try my hand at some driveway grading. It was working decently well (once I set the blade angle to the least aggressive) until I tried to push too much material. The engine bogged down and died. This happened again a few times soon thereafter, including a couple of times under no appreciable load. It almost sounded like it wasn't getting enough fuel. I filled the tank again and continued grading until once again I overloaded it and it began to bog down again. This time I choked it right as it was bogging down, and that gave it enough life to keep running (but not well.) I could keep the machine running by making frequent, fine adjustments to the choke, but it would never really get chugging. When I turned it off and then turned it back on again, it ran normally again for the rest of the day. Could this have to do with the previously mentioned self-flooding issue, which was likely the result of contaminants in the gas tank? Share this post Link to post Share on other sites
