Heatingman 971 #1 Posted August 31, 2022 Is there a teardown manual for this? Or a good thread about it? Share this post Link to post Share on other sites
ebinmaine 74,249 #2 Posted August 31, 2022 There are several threads that would be helpful because these transmissions are so similar. To find them go to Reference section Transmissions You'll see threads for 6 speed, 3-speed, and others like this one for a 4 speed. 4 Share this post Link to post Share on other sites
rmaynard 16,495 #3 Posted August 31, 2022 The transmission service manual is great. Well written with lots of illustrations. However, @stevasaurus video is even better. 2 4 Share this post Link to post Share on other sites
Pullstart 67,942 #4 Posted August 31, 2022 I believe the reference section of this forum is hidden in plain sight… there sure is a ton of good reads in there! 5 Share this post Link to post Share on other sites
The Freightliner Guy 1,363 #5 Posted August 31, 2022 Share this post Link to post Share on other sites
ebinmaine 74,249 #6 Posted August 31, 2022 4 minutes ago, Pullstart said: I believe the reference section of this forum is hidden in plain sight… there sure is a ton of good reads in there! Agreed. I'm terrible about remembering to look there before I ask silly questions that have been answered 7,000 times already. 2 Share this post Link to post Share on other sites
peter lena 9,406 #7 Posted August 31, 2022 @Heatingman https://www.amazon.com/Bottle-Stainless-Bristle-PMD-Products/dp/B007S91ND4/ref=sr_1_11? used this type of hole cleaner after a steering wheel pull , also available in brass , used never seize to install that mount pin , when I started removing wheels , I braced the side of the wheel , with a solid wood , 4x4 to wall beam , eliminating wheel bounce , size to size flat round punch , 3lb hammer , the first hit made it move . since then my steering wheels ,are removed without any problems , pete 1 1 Share this post Link to post Share on other sites
peter lena 9,406 #8 Posted August 31, 2022 @Snoopy11 yup that wheel impact bounce , was my , have to change this moment , bolted 1 side of a 2 piece pipe clamp , on to the 4x4 , then clamped it around the steering wheel base , then put the end up against a corner wall beam , 3 lb hammer / punch , never looked back . never seize, pete Share this post Link to post Share on other sites
gt14rider 968 #9 Posted August 31, 2022 4 hours ago, ebinmaine said: Agreed. I'm terrible about remembering to look there before I ask silly questions that have been answered 7,000 times already. I'm guilty of that,would have saved you all a lot of questions. Have trouble finding old posts with the search engine on this site. Forgot about that reference section. 1 Share this post Link to post Share on other sites
953 nut 61,762 #10 Posted August 31, 2022 1 hour ago, gt14rider said: Have trouble finding old posts with the search engine The more you do it the easier it becomes. 1 Share this post Link to post Share on other sites
ebinmaine 74,249 #11 Posted August 31, 2022 2 hours ago, gt14rider said: I'm guilty of that,would have saved you all a lot of questions. Have trouble finding old posts with the search engine on this site. Forgot about that reference section. 10 minutes ago, 953 nut said: The more you do it the easier it becomes. One little tidbit I've learned is to type in 2 or 3 words. Hit the magnifier to search, then tap the key that shows the words I used connected by "AND". Then poke down through til I find what I want. Share this post Link to post Share on other sites
