Maxwell-8 4,370 #1 Posted August 30, 2022 (edited) A local WheelHorse owner I know needs some help on his C161 ( 91-16BS02-18159 ) It's a sundstrand hydro and he can not control the speed of his tractor, it slows down, then it raises speed. There is a plastic (eton) plate (60) that is connected to a pin he says. He says there is a lot of play in that connection . He wonders if he is missing something that leads to that play. If claims that plastic plate (60) is pretty much new. I have a picture with the plate (60) but without the handle Any Help is much appreciated. Edited August 30, 2022 by Maxwell-8 Share this post Link to post Share on other sites
squonk 45,591 #2 Posted August 30, 2022 worn pin #56 Broken frame where the trans bolts on or broken tab on lest side of tractor where the hydro linkage passes thru the tunnel 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #3 Posted August 30, 2022 How is it in reverse? Don Share this post Link to post Share on other sites
Maxwell-8 4,370 #4 Posted August 30, 2022 7 minutes ago, Snoopy11 said: How is it in reverse? Don I think same story 8 minutes ago, squonk said: worn pin #56 Broken frame where the trans bolts on or broken tab on lest side of tractor where the hydro linkage passes thru the tunnel Thanks for the input 1 Share this post Link to post Share on other sites
squonk 45,591 #5 Posted August 30, 2022 Possible broken acceleration spring too 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #6 Posted August 30, 2022 Here is an original parts list for this model 1 Share this post Link to post Share on other sites
