Heatingman 977 #1 Posted August 30, 2022 Thumbing through the K series engine manual, I noticed that on the general schematics, they dont show a light wired in on the 25 amp alternator coil, but they do on the 30 amp. Does that indicate the 25 amp wont support head lights? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #2 Posted August 30, 2022 It will support lights. Share this post Link to post Share on other sites
subvet720 179 #3 Posted August 30, 2022 (edited) I made a few post on the regulated 12VDC power supply I made using 4 diodes and a buck converter. With LED headlights ( https://www.amazon.com/dp/B075QZHXC6?psc=1&ref=ppx_yo2ov_dt_b_product_details ) and the 12VDC power supply, my K241 runs lots of LED lights because the current draw in minimal. Edited August 30, 2022 by subvet720 Add Photo 2 Share this post Link to post Share on other sites
953 nut 63,031 #4 Posted August 30, 2022 The headlights furnished with your Wheel Horse were 35 Watts each, that is about three amps each (six amp draw for lights). If your engine has a battery powered ignition it will draw four amps so the total likely draw is 10 Amps. 2 Share this post Link to post Share on other sites
subvet720 179 #5 Posted August 30, 2022 The LED headlamp bulbs only draw 0.75 amps, are much brighter and will outlast the driver of the tractor 2 Share this post Link to post Share on other sites
Handy Don 15,202 #6 Posted August 30, 2022 6 hours ago, subvet720 said: using 4 diodes and a buck converter Did you get the buck converter from Adafruit? Share this post Link to post Share on other sites
Heatingman 977 #7 Posted August 31, 2022 16 hours ago, subvet720 said: I made a few post on the regulated 12VDC power supply I made using 4 diodes and a buck converter. With LED headlights ( https://www.amazon.com/dp/B075QZHXC6?psc=1&ref=ppx_yo2ov_dt_b_product_details ) and the 12VDC power supply, my K241 runs lots of LED lights because the current draw in minimal. Whats the necessity of a second rectifier/regulator? Or is this in place of the OEM? Share this post Link to post Share on other sites
subvet720 179 #8 Posted August 31, 2022 19 hours ago, Handy Don said: Did you get the buck converter from Adafruit? The buck converter is courtesy of Jeff Bezos and Amazon. Share this post Link to post Share on other sites
subvet720 179 #9 Posted August 31, 2022 (edited) 9 hours ago, Heatingman said: Whats the necessity of a second rectifier/regulator? Or is this in place of the OEM? This is in addition to the OEM rectifier/regulator. This allows you to set up multiple DC voltages (3V, 5V, 12v) for LED components that may be sensitive to unstable voltage spikes. Additionally, it's cool because you made it for ~$4 Edited August 31, 2022 by subvet720 2 Share this post Link to post Share on other sites
