Jerry Ohmer 1 #1 Posted August 18, 2022 (edited) Classic GT Will not start. Replace the starter solenoid. Still just clicks when trying to start it. im guessing a safety switch is to blame. How is the easiest way to test these safety switches without replacing them all ? Edited August 18, 2022 by Jerry Ohmer Share this post Link to post Share on other sites
squonk 45,809 #2 Posted August 18, 2022 (edited) If your solenoid is actually clicking it's not a safety switch. A bad switch would prevent the solenoid from clicking. Sounds like the starter. Do you have a voltmeter? You can download the Demystifcation guide here for wiring diagrams https://www.wheelhorseforum.com/files/ Edited August 18, 2022 by squonk 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,066 #3 Posted August 18, 2022 Download this file. Each circuit has it's own diagram. 1 Share this post Link to post Share on other sites
Handy Don 16,062 #4 Posted August 18, 2022 This could be as simple as a poor electrical connection. Components don't fail often, but the connections do, Are all the connections in the start circuit clean and tight? If the solenoid is clicking, but the starter isn't turning the likeliest situation is not enough juice to the starter. Start with the battery connections and the negative to ground connection. You replaced the solenoid so you cleaned and tightened all of those, right? (If not, you don't lose your turn but you must go back two spaces and roll again. ) The demystification guide has trouble-shooting sequences. You will need a test lamp, or, even better, a trusted volt-ohm meter and some wire for jumpers. 3 Share this post Link to post Share on other sites
953 nut 64,649 #5 Posted August 18, 2022 The first thing you should do with any electrical problem is take the battery to an auto parts store and have it load tested. Once you have a confirmed good battery in the tractor and ALL connections including grounds cleaned and tightened. Take a 12 volt test light or volt meter set at 20 volts DC, attach the negative lead to your battery ground point and touch the positive probe to the battery positive terminal to see that it is working. Now move the probe to the solenoid battery side and activate the starter switch, if there is a click but the light/voltage reduces greatly or goes away you have a bad cable from the battery to the starter. If there is no click take a small jumper wire from the "+" battery post to the small terminal on the solenoid that goes to the ignition switch, this should close the solenoid and you can observe the voltage as previously mentioned. Presuming the light/voltage test was satisfactory move the probe to the starter side of the solenoid and repeat, if the solenoid closes but the light/voltage reduces greatly or goes away you have a bad solenoid. Presuming this test was satisfactory move the probe to the starter end of the cable from the solenoid and repeat, if the solenoid closes but the light/voltage reduces greatly or goes away you have a bad solenoid to starter cable. If this test was also satisfactory but the starter didn't turn over take a good quality automotive jumper cable and connect one end of the black wire to the engine and the other end to the battery negative terminal and try again. If the starter turns over the ground cable is bad. If that didn't do the trick then connect one end of the red jumper cable to the starter and touch the other end to the battery positive terminal to test the starter itself. 3 Share this post Link to post Share on other sites
Snoopy11 5,731 #6 Posted August 19, 2022 21 hours ago, squonk said: A bad switch would prevent the solenoid from clicking Precisely... and it would be helpful to know WHAT is clicking when the key is turned... the solenoid... starter... what exactly... A little further diagnosis is needed. Is something prohibiting the engine from turning over... perhaps a mouse hotel in the flywheel? Don 1 Share this post Link to post Share on other sites
Jerry Ohmer 1 #7 Posted August 24, 2022 ThankYou, For All Your Feedback. Turns out the Magnet Assemble has come off the Gear Shift Lever. Machine is operating again. 😎 1 Share this post Link to post Share on other sites
