russellmc301 601 #1 Posted August 15, 2022 I have a wheel horse no name 14 that has a 42 inch deck. The center pulley seems to be missing something as the pulley is smooth and the shaft has square sides. Can someone please tell me what seems to be wrong? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,256 #3 Posted August 15, 2022 Flat sided shaft known as 5/8" x 3/4" double-D Pulley should match 1 1 Share this post Link to post Share on other sites
daveoman1966 3,882 #4 Posted August 15, 2022 You center pulley is partr # 106847. It should look like this...your is cimoletely wallowed out. 2 Share this post Link to post Share on other sites
peter lena 9,893 #5 Posted August 15, 2022 @russellmc301 , going to do anything with those spindle bearings ? look long over due , that flat idler pulley is probably noisy too , pete Share this post Link to post Share on other sites
russellmc301 601 #6 Posted August 15, 2022 Wonderful thank you for the responses! The other bearings do seem to be noisy. Do you know what bearings would replace them? Share this post Link to post Share on other sites
peter lena 9,893 #7 Posted August 15, 2022 @russellmc301 if you are going to be replacing those deck bearings , someone will probably give you the bearing # , opportunity is the most important part of a bearing swap , recommend doing a grease change on those new bearings , if the bearings have wide rubber side shields , flat pocket screwdriver , carefully remove the seals , wipe out original grease , flush with carb cleaner , repack with lucas x-tra heavy duty chassis grease , walmart green and white tube , 560 temp rating , anti sling , polyurea ( recovering ) rated , imagine quiet bearings , no whining hi pitch noise ! I also re grease my mule drive bearings , and the needle bearing in the pto drive cone . years of reliable use , no noise or failures , questions , just ask , pete Share this post Link to post Share on other sites
