Jack11 32 #26 Posted August 16, 2022 WE GOT HER RUNNING BOYS IMG_1671_(1).mov 3 6 Share this post Link to post Share on other sites
Moparfanforever 926 #27 Posted August 16, 2022 Sounds good !! How did you get it started?? Share this post Link to post Share on other sites
Jack11 32 #28 Posted August 16, 2022 42 minutes ago, Moparfanforever said: Sounds good !! How did you get it started?? Followed above ^^ Drained the gas and oil and refilled.Threw a battery tender/starter on and sprayed the carb with engine starter! Started right up. Doesn't sound super strong but its running! 1 Share this post Link to post Share on other sites
D_Mac 9,334 #29 Posted August 17, 2022 (edited) Sounds pretty good. C series are tough to beat. For 30 bucks you got a great deal. Won't take much to get it looking a lot better. A good cleaning and degreasing and a rub down with some boiled linseed oil and it will look 25 years newer. Good luck with it. Edited August 17, 2022 by D_Mac 1 Share this post Link to post Share on other sites
Ed Kennell 45,584 #30 Posted August 17, 2022 She sounds like a $400 tractor. In addition to all the normal maintenance stuff recommended above, I'll add two items. I was never a fan of the rubber mounted engines. I would replace the rubber with metal spacers or washers. The under the seat fuel tank can cause fuel delivery problems on start up. When the tractor sits, over time, the fuel will drain back into the tank and the fuel pump will lose it's prime. An easy fix is to install a marine primer bulb in line to prime the pump before starting. 1 Share this post Link to post Share on other sites
stegs 327 #31 Posted August 17, 2022 17 hours ago, fitz said: WE GOT HER RUNNING BOYS IMG_1671_(1).mov told you they are bullet proof, and it sounds great to me. Sounds just like my 141!! I love that kohler single whine/howl. Thats when you know the old girl is in its "sweet spot" 1 Share this post Link to post Share on other sites
peter lena 9,827 #32 Posted August 17, 2022 @fitz , easy to drop the carb bowl , do that carefully , so you do not rip a gasket , have also run in a used engine in a separate gallon jug of heavily treated fuel , watch the color of your oil for changing , thats indicating cleaning / flushing , get hours on that oil , do hot oil changes , for a more thorough drainage . do a thorough baseline service , verify what works and doesn't , plan on a transmission drain , shift boot torn? , would indicate possible milky oil in trans . go at it thoroughly , aerosol spray lubricant , make the rust run out , lift up front axel off ground to grease it , grease out the top of axel spindle , 4 fittings , center axel swing point , 2 axel spindles , steering gear " fan " area . also get some penetrant into the choke and throttle cables . AGREE WITH @Ed Kennell on the possible fuel primer bulb ,or a fuel check valve , between fuel pump and carb . lots to look at and learn . ask questions , pete 1 Share this post Link to post Share on other sites
Heatingman 977 #33 Posted August 18, 2022 (edited) On 8/16/2022 at 10:31 AM, fitz said: She is home - does not start so the "100% works" statement on the auction listing was not correct (SMH). Purchased for $29.66 so not super concerned. I turn the key and abs. nothing (click or anything) so I think its the battery. I will hook it up to a tender/starter later. What auction site? I could go 1/2’s on a 30 dollar tractor - cash! And look at that seat! Like new! Edited August 18, 2022 by Heatingman Share this post Link to post Share on other sites
