decvt79
1999 Toro 270H model 72106 parts needed
decvt79
I recently posted about issues with my transmission and have now identified the issue.   I removed the transmission cover and found that the final pinion bearing had failed.   Bearings and race in bottom of cover.   Now need to find replacement bearing and also a new filter.   Bearing part number from Toro is 93-0446 and is stamped with “Japan Nachi 6203”.  The gasket is Toro # 93-0478.   Any help verifying these part numbers for a TORO 270H model 72106 and also locating replacement parts or equivalents would be greatly appreciated.  My transmission serial number is 049132.  Thank you!
Achto
gwest_ca
The 6203 bearing is easy - likely the same in the mower deck spindles.
peter lena
@decvt79 ah yes the infamous 6203 lubrication failure , what an opportunity !  something thats very easy to do , https://www.bing.com/search?FORM=UP97DF&PC=UP97&q=lucas+x-tra+heavy+duty+grease  , when you get that bearing , notice the wide rubber side shields on it ? small pocket flat screwdriver , carefully  remove both shields , clean cloth wipe out  "  lubricant " , finish cleaning with carb cleaner , till dry , repack to same amount with the  lucas grease .reinstall seals   heat rated to 560 deg , anti sling , and polyurea rated  ( recovering ) . done this on my mower decks , no whining bearings and no failures . only a suggestion , but those 6203 bearings are basically a ceiling fan bearing , unless they are repacked with a hi temp grease , they fail , would also use same grease in similar friction areas , pete
peter lena
@decvt79   , there you are , the size / shape of the bearing is very popular , its the angular heavy loading that really kills it , lubrication wise. the same bearing is used in the mower deck , mule drives , that very typically get into the whining zone very early on in usage. when I first got into horses , a glairing failure to me , was lubricant failure . since going to that  lucas hd chassis grease . zero / no failures or noise . my 3 horses have it in practically every stage of hot lubrication , also use the lucas red and tacky aerosol spray grease , in tight spot areas , linkage ends . as you build / put together your unit , look out for opportunities to improve , the function of areas . have any stiff cables ?  try synthetic super lube , comes in paste /  small tube oil , makes things work with ease , good luck with it , pete
decvt79
thanks for the information.  This bearing is not sealed and is submerged in the transmission hydraulic fluid.   I was told by a friend to use a synthetic fluid when I rebuild it which I will likely do.   I’m now looking for the filter for my K61A transmission.   There are a few online from various vendors but not positive they will fit.   Do you have any recommendations?
peter lena
@decvt79  sorry to confuse you , thought it was a self grease mount , agree with the synthetic  trans fluid , as long as the filter  meets the specs for a  K 61A TRANS , you should be good , you might check on the temp range on the atf , was noticing that honda has a specific  temp rated oil , to insure function , you might find some related specs on your trans , that has specific atf  chemical make up . just ask that trans oil question on line , you could check , THE OIL GUY , usually has good info , pete
peter lena
 @decvt79  found it , bob the oil guy , looks like 5-30  synthetic oil , check out the site , pete
  • Similar Content
    • Evguy
      By Evguy
      B100 8 speed and short chute snowblower for sale near Indianapolis Indiana.
      good deck and tires, kohler engine runs.
      transmission needs axle seals and bearing.
      needs steering wheel also.
      too many projects, not enough room.
    • blu_stang
      By blu_stang
      Hi All, It's time for me to sell the D-250 I've had for the last 8 years.  It’s useable as is, or would be a great project bundle for further restoration.
      I am selling a large package: the running tractor, a refurbished snowblower (48”), parts snowblower, mower deck (60”), tiller (40”), front plow blade (60”), Cat 0 3-Point Hitch with adjustable top link, WH 3-Point tool bar, wheel weights and tire chains.  Also included is an extensive part collection, nearly a second tractor worth.  I will include the original manuals, an original 1976 sales brochure, and repair manuals for the tractor and the engine.  I made electronic copes of all of the above, and stored the paper copies to prevent further wear. This is one of the most complete D-250 tractor/attachment bundles I’ve seen.
      Some highlights from the available parts: Frame rails, extra engine, water pump, extra transaxle, extra gears, including worm gears (stored in oil bath), Front wheel set, carburetor, carb rebuild kit, rebuildable original radiator, extra radiator overflow bottle, rebuilt alternator, new voltage regulator (I was planning to change over to an alternator setup from the generator), new in package Renault engine seals, new PTO seals, ignition maintenance parts.  There are also many panels, frame pieces, cables, levers, tubes (lines) and hardware in the collection.
      The tractor engine runs smooth.  There are around 1050 original hours on it; It’s a 1976 edition.  Everything works, except the dash lights and the rear lights (disconnected b/c of fender).  I just haven't sorted out the wiring, but it is all there.  Headlights are good and working, as are all of the gears and levers.  The four tires are nearly new Carlisle Multi Trac, with nubs still on them.  The rear tires have been filled (ballasted) with Rim Guard for extra traction.  The hydraulic pump, front PTO clutch and brakes operate but could use a tune up.  I’ve used it for mowing and snowblowing on hills, driveway and around my land. I don’t have an original WH seat.  The snowblower was rebuilt a few years back, and assembled with all new hardware and bearings.  The mower deck gearbox was professionally serviced recently, and has a new set of blades with only a half dozen mows.  The rear fender needs a repair, but all pieces are available.  The plow and tiller are due for restoration.  The Points, Condenser and rotor have all been replaced and tuned in.  The battery is good.  I've rebuilt the carb, replaced the fuel pump and changed out the plugs within the last 30 hours.  The replacement radiator is from a Kawasaki engine; it was installed with new hoses. There are also new custom hydraulic hoses and a new hydraulic lift cylinder.
      Here's a video of me mowing, this past summer.
      Transporting this haul in one trip will require a pickup truck and a large trailer.
    • Merl
      By Merl
      Newbie here and I have a 520-H that runs, but needs some TLC and some minor things fixed and/or adjusted. It comes with a like new tiller that I believe has only been used once and has paint still on the tines. I am the 2nd owner and I have personally never used the tiller. I am selling my previous home that I rent and where it has been stored. My current home's yard just isn't big enough to use a rider and I need to find a new home for it. I want to sell them together to simplify and I need them gone in the next 2 weeks. Please reach out with any questions and I'll do my best to answer. I am definitely not as knowledgeable as most of you on this forum, but figured somebody would like to fix it up, part it out and/or needs a tiller. Please email or text.
    • mbalsup
      By mbalsup
      Hi all,
      Not a Wheel Horse fan but recently had a WH 656 given to me. It seems complete with the exception of the steering wheel. Might anyone have an appropriate steering wheel for sale or can point me to where I can find one? Thanks
      Mike Alsup
      Dekalb, IL
      mbalsup@gmail.com
    • Bach-Ed
      By Bach-Ed
      It's been a while since I've been here.  My 857 just keeps humming a long.  But a while ago I picked up some parts, thinking they would fit my machine but no.  so here are some pics  they seem to be NOS.   I'm sure one of you would love to have them and I would have a little more shelf space.
