Heatingman 977 #1 Posted July 26, 2022 I’ll be painting in the next couple weeks. Originally I bought and planned to use Kylon Implement paint. I am second guessing that choice. As I have read some reviews that it does not dry properly. So I am thinking about returning the paint and getting Rustoleum implement instead. planning to buy quarts or pints and use a spray gun. also read epoxy primer may be the way to go also. Is their a good one I can source on Amazon? Share this post Link to post Share on other sites
Prestons Hobby 76 #2 Posted July 26, 2022 I personally prefer to use a Red Oxide primer. It is not the same as it was 20 years ago but I have had good results with rust not reappearing. As far as the implement paint, I typically use the 2-part epoxy paint and put a light coat on for the first coat and let it get tacky so it does not produce “runs” and then apply a second coat just a little heavier. (Key word little) the 2-part epoxy seems to hide a lot of sins without hours of sandpaper work. If there is a better method or system out there that works better I’d love to hear some off them because I too will be painting a couple of tractors myself very soon. Share this post Link to post Share on other sites
pacer 3,181 #3 Posted July 26, 2022 I use the common Rustoleum in both quart and rattle can for a couple reasons. For starters its relatively inexpensive (so far!!) and readily available and after 10-12 yrs using it I find its a good paint. For large pieces I use a spray gun with a dab of acetone and a dab of hardener, and It dries reasonably quickly. I use the rattle cans for the small pieces. Another is I build my horses to please my self and use them (no trailer queens) From being on this forum for a number of yrs, I have a strong suspicion that a goodly number of members use Rustoleum. 2 Share this post Link to post Share on other sites
ri702bill 13,271 #4 Posted July 26, 2022 3 hours ago, Heatingman said: also read epoxy primer may be the way to go also. Be CAREFUL with any 2 part paints - a GOOD respirator must be used as that stuff in the air is lethal. If you wish to see your unborn grandkids - don't just use a dust mask. BTW - how many body shop guys you know that lived to retire?? That is a rather exclusive club... Bill (a former spray painter and can still talk about it...) 3 1 Share this post Link to post Share on other sites
Heatingman 977 #5 Posted July 26, 2022 32 minutes ago, pacer said: I use the common Rustoleum in both quart and rattle can for a couple reasons. For starters its relatively inexpensive (so far!!) and readily available and after 10-12 yrs using it I find its a good paint. For large pieces I use a spray gun with a dab of acetone and a dab of hardener, and It dries reasonably quickly. I use the rattle cans for the small pieces. Another is I build my horses to please my self and use them (no trailer queens) From being on this forum for a number of yrs, I have a strong suspicion that a goodly number of members use Rustoleum. Yes, while I want it to look a certain way, I am restoring it to make it new again to use it. For mowing and plowing. I mainly want the paint to hold up for a good long time Share this post Link to post Share on other sites
pacer 3,181 #6 Posted July 26, 2022 This is what I try to end up with...... Thats Rustoleum Sunrise Red. 3 Share this post Link to post Share on other sites
oliver2-44 11,791 #7 Posted July 28, 2022 I'll add these pictures so you can see this Rustoleum Regal Red (with hardener) next to pacers Sunrise Red. (I like both colors) while this picture is just after restoring, Its going on 6 years and has held up very well It interesting how in different light this looks a lighter than the above picture, same tractor. 3 Share this post Link to post Share on other sites
Heatingman 977 #8 Posted July 29, 2022 So I have returned the krylon. Have not totally settled on what I will use for the tractor itself yet. I want to paint different parts, different colors. Frame - either grey or black, fender and hood, a variety of red, Plow and mower deck some type of orange/yellow, like Catepillar uses. Was having a hard time sourcing Rustoleum locally in the quantities I want for use in a spray gun. None of the usual suspects have the right colors. Today I stopped in at the local Ace, whom I typically bypass cause the pricing is usually much higher then the bigger players. Surprised to find that not only is their price competitive, they also have a much wider selection of Rustoleum and they also have their own brand of implement paint as well, which I may try for some portions. Not quite to the point of being ready to paint, but some parts are really close. Still got of few parts to sand blast and prep. And bolts to prep also. Maybe end of next weekend. I will be ready for paint. Share this post Link to post Share on other sites
ineedanother 2,885 #9 Posted July 29, 2022 3 minutes ago, Heatingman said: Today I stopped in at the local Ace, whom I typically bypass cause the pricing is usually much higher then the bigger players. Surprised to find that not only is their price competitive, they also have a much wider selection of Rustoleum and they also have their own brand of implement paint as well, which I may try for some portions. I shop Ace a bit. Franchises with local ownership which I can appreciate. Some things there beat the big two hands down as far as hardware and such for the homeowner. I've used the Ace Premium enamel on shop equipment with good results. Made in the USA. I wouldn't hesitate to use it again. 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,777 #10 Posted July 29, 2022 All you ever or never wanted to know about paint… check out this thread: Share this post Link to post Share on other sites
Handy Don 17,634 #11 Posted July 29, 2022 15 hours ago, ineedanother said: I shop Ace a bit. Franchises with local ownership which I can appreciate. Some things there beat the big two hands down as far as hardware and such for the homeowner. I've used the Ace Premium enamel on shop equipment with good results. Made in the USA. I wouldn't hesitate to use it again. Similar experience--I'm ok with 5% higher price to keep the local franchisee in business. Their Hillman hardware bins are much more frequently maintained so very rare not to get what I need. The Ace version of "anti-rust" paint has worked well where I've used it on non-WH equipment. A LOT depends on how the shop is run. We had another ACE that went out of business in a stellar location but he didn't have enough space and it was poorly run. Share this post Link to post Share on other sites
squonk 48,287 #12 Posted July 29, 2022 I find Sunrise Red to orangey for me. Remember colors vary from person to person so you Sunrise guys don't hate me. I use Regal Red and when my final coat is still wet, I spray on Rustoleum Chrystal Clear. Everything dries pretty quick and looks good Share this post Link to post Share on other sites
Heatingman 977 #13 Posted July 29, 2022 Anyone use any additives? Like Japan Drier to speed the drying? Or Penetrol to improve durability? looked into traditional automotive paints, primers, and clears. Prices are way out of budget for a lawn tractor. Especially for wanting multiple colors. Share this post Link to post Share on other sites
Heatingman 977 #14 Posted July 31, 2022 Well finally starting to make some progress. plow and all its hardware got a few coats of red oxide primer. Share this post Link to post Share on other sites
oliver2-44 11,791 #16 Posted August 1, 2022 (edited) On 7/29/2022 at 12:14 PM, Heatingman said: Anyone use any additives? Like Japan Drier to speed the drying? Or Penetrol to improve durability? looked into traditional automotive paints, primers, and clears. Prices are way out of budget for a lawn tractor. Especially for wanting multiple colors. I use Majic brand Enamel hardener with Rustoleum Regal Red paint. It’s available at Tractor Supply [don’t use their Majic paint-poor quality]. I’ve also used this hardener with Sherwin Williams oil based enamel to paint cabinets. So it seems to work with many brands. With it the paint seems to dry a little faster, harder, and it adds a little more gloss shine. I believe several on here use an enamel hardener, there are a few brands out there. Please wear a good quality respirator using it. Edited August 5, 2022 by oliver2-44 1 Share this post Link to post Share on other sites
Heatingman 977 #17 Posted August 1, 2022 2 hours ago, oliver2-44 said: I use Majic brand Enamel sharpener with Rustoleum Regal Red paint. It’s available at Tractor Supply [don’t use their Majic paint-poor quality]. I’ve also used this hardener with Sherwin Williams oil based enamel to paint cabinets. So it seems to work with many brands. With it the paint seems to dry a little faster, harder, and it adds a little more gloss shine. I believe several on here use an enamel hardener, there are a few brands out there. Please wear a good quality respirator using it. you just use the ratio shown on the can? Share this post Link to post Share on other sites
Heatingman 977 #18 Posted August 1, 2022 Well I picked up some of that hardener. And used it with the Ace Brand Rust Stop implement paint (oil based enamel) went with roughly 16 to 1 and a little naptha for thinning. Went fairly well, got the plow parts painted. Guessing it wont be dry enough to move around till morning. Not sure what if any effect the harder will play on dry time. Seems oil based just takes a lifetime to dry. Share this post Link to post Share on other sites
jeepdan 337 #20 Posted August 2, 2022 I have been using 8 to1 ratio of the Majic hardener/catalyst + 1 part Majic enamel reducer added to Rust Oleum farm & implement paint. High gloss and dries fast. You can handle painted parts in about eight hours. Share this post Link to post Share on other sites
Thor27 892 #21 Posted August 4, 2022 On 7/29/2022 at 10:14 AM, Heatingman said: Anyone use any additives? Like Japan Drier to speed the drying? Or Penetrol to improve durability? looked into traditional automotive paints, primers, and clears. Prices are way out of budget for a lawn tractor. Especially for wanting multiple colors. I like to use 2 cap fulls of flood penetrol, a cap full of japan black, and a splash of the majik hardener in regal red. I don't know if penetrol does anything for durability, but it does seem to lay down better. I credit the hardener for durability and scratch resistance.. Don't know if the japan dryer is doing anything for me honestly. Share this post Link to post Share on other sites
Heatingman 977 #22 Posted August 4, 2022 (edited) Not happy with the paint durability. sprayed the primer over the weekend, was pretty happy with that. sprayed the top coat Monday I think. Its been curing for a few days. started reassembly of the plow. Seems like if I look at the finish the wrong way it chips off. Either the hardener is not compatible with the Ace Rust stop paint, or its just garbage paint. Set it on a piece of wood today, and I mean gently set in order to get the blade elevated, and when I readjusted the position, paint came off. Im practically wearing kid gloves moving this around. One part touches another during reassembly, both get a chip. Primer is the same brand and series and made to be used with oil based. Back to the drawing board I guess. gonna have to make some test pieces and test durability / add in compatibility before I coat the rest of the pieces and strip down and recoat this one Edited August 4, 2022 by Heatingman 1 Share this post Link to post Share on other sites
Heatingman 977 #23 Posted August 4, 2022 Also what looks like runs in the paint in the above pic, its some oil I used to lubricate in that area, as thats where the plow pivot is. Maybe Im just too impatient, not sure. But I would think 4 1/2 days is plenty to cure enough to move gingerly without huge chunk removal. Maybe the pressure washer will take this off. Really not wanting to sandblast again outside the cabinet. Scrapping off real easy so far. Share this post Link to post Share on other sites
Heatingman 977 #24 Posted August 6, 2022 Did a little paint comparison testing. rusto implement paint I had on hand - happened to be JD yellow (I used for a chop saw cabinet) no additives the Ace rust stop oil based - equipment yellow no additives and the Ace rust stop enamel from a spray can. after a day - the spray can hardened fine to the finger nail, the others still not - to be expected. after 2 days the Rusto oil based passes the nail test. after 3 days the Ace still fails with ease. Either that paint just takes forever to cure, or its gone bad, or … Share this post Link to post Share on other sites
gt14rider 1,283 #25 Posted August 7, 2022 Regal Red dries faster Share this post Link to post Share on other sites
