23 Reo 234 #1 Posted July 25, 2022 How do I test a starting relay and a PTO safety switch on a 1994 416? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,066 #2 Posted July 25, 2022 Download this file for wiring. The diagram for the start circuit may help. You may have the same relay used in another circuit so trading them may be an option. Very popular relay so should be easy to get a spare. Different relay but this explains how they work and how to test Pto switch 2 1 Share this post Link to post Share on other sites
Pullstart 69,237 #3 Posted July 25, 2022 Do you have a meter? Continuity will be your friend! 1 Share this post Link to post Share on other sites
23 Reo 234 #4 Posted July 25, 2022 Yes, I have a meter and know how to use it. I also have a nice test light that shows volts. I am still learning electrics, but can do the job when instructed. Share this post Link to post Share on other sites
23 Reo 234 #5 Posted July 27, 2022 Tested the relays and the're good. On to the safety switches. Thank you, Dave Share this post Link to post Share on other sites
23 Reo 234 #6 Posted August 5, 2022 Will a faulty oil pressure switch keep the Onan 216 from starting? 1 Share this post Link to post Share on other sites
lynnmor 8,684 #7 Posted August 5, 2022 2 hours ago, 23 Reo said: Will a faulty oil pressure switch keep the Onan 216 from starting? The oil pressure switch turns on the oil pressure lamp when there is no pressure, on some models it also turns on the hour meter when there is pressure. There is no other function, so the answer is no. 1 Share this post Link to post Share on other sites
23 Reo 234 #8 Posted August 6, 2022 (edited) Is there a neutral safety switch on my 1994 416? Is it the same switch as the parking brake switch? If there is an independent neutral switch where is it's location? Edited August 6, 2022 by 23 Reo Share this post Link to post Share on other sites
ahiacanon 1 #9 Posted May 9, 2023 https://kwiga.com/quiz-builder is the perfect quiz builder for WordPress users who want a fast, easy, and effective way to create and publish quizzes on their website. Our platform is designed to be user-friendly, even for beginners, with a drag-and-drop editor that lets you easily customize your quizzes to match your brand. Plus, with our built-in lead capture and email integration features, you can use your quizzes to grow your email list and drive more sales. Share this post Link to post Share on other sites
