mrharris12 33 #1 Posted July 20, 2022 Hi all, I turned the 418-c off after cutting the grass on the backside of my property and when I went to start it up a few minutes later I got nothing when turning the key. Later found out that the solenoid was not getting any juice so I am fairly certain it is the ignition. I am currently having a hard time finding the ignition for this within Toro's website, does anyone know the part # I would need? Share this post Link to post Share on other sites
Achto 30,204 #2 Posted July 20, 2022 23 minutes ago, mrharris12 said: Later found out that the solenoid was not getting any juice so I am fairly certain it is the ignition. The ignition has nothing to do with the starter. I would be looking into a safety switch that is not working. PTO switch, or clutch switch will keep the starter from engaging. 5 Share this post Link to post Share on other sites
Jeff-C175 7,207 #3 Posted July 20, 2022 9 minutes ago, Achto said: The ignition has nothing to do with the starter. I'm thinking he meant the ignition switch? But yeah, safety circuits should be examined. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #4 Posted July 20, 2022 Look at the wiring diagrams Share this post Link to post Share on other sites
953 nut 63,031 #5 Posted July 20, 2022 10 hours ago, mrharris12 said: turned the 418-c off after cutting the grass Is the PTO engaged? 1 Share this post Link to post Share on other sites
mrharris12 33 #6 Posted July 20, 2022 10 hours ago, Achto said: The ignition has nothing to do with the starter. I would be looking into a safety switch that is not working. PTO switch, or clutch switch will keep the starter from engaging. So I know the switch underneath the seat is either unplugged or disengaged because I can get off the tractor while the blades are on and it wont cut off, previous owner must have done that. So i dont think that switch is causing the issue. I will need to find out where the PTO switch and clutch switch is and see how those are looking 1 Share this post Link to post Share on other sites
mrharris12 33 #7 Posted July 20, 2022 59 minutes ago, 953 nut said: Is the PTO engaged? when trying to turn it on, no. I think thats what you are asking?? I was able to jump it by using a screwdriver and contacting the two bolts from the solenoid, but i didnt try to engage the pto. Share this post Link to post Share on other sites
Achto 30,204 #8 Posted July 20, 2022 15 minutes ago, mrharris12 said: So I know the switch underneath the seat is either unplugged or disengaged because I can get off the tractor while the blades are on and it wont cut off The function of the seat switch is to kill the engine if you try to leave the seat with the PTO engaged. This function does not effect the starter. Turn the key switch to the start position and see if you have power at the Tan wire coming out of the switch. The Tan wire will then go in to the PTO switch, test to see if power is getting to this point. Next test the Purple wire coming out of the PTO switch. This wire should have power with the key in the start position and the PTO in the off position. The Purple wire will then go to the Clutch switch, test to see that power at this point. Next see if you are getting power to the Lt. Blue wire at the clutch switch. Key in start, PTO off, clutch peddle pushed in. The Lt. Blue wire then goes to the starter solenoid. Next check for power on the Lt. Blue wire on the solenoid. If power is getting all the way to the Lt. Blue wire on the solenoid with the Clutch pushed in, PTO off, & the key in the start position but the starter will not engage. Check solenoid for a good ground. Check battery connections at the solenoid and the battery. Replace solenoid. 2 1 Share this post Link to post Share on other sites
oldlineman 1,591 #9 Posted July 20, 2022 Great answer Achto, I just chased that rabbit on a 310-8 and you nailed it step for step. My problem was the PTO switch was not closing with the PTO disengaged. I did exactly the steps and found the problem. Great steps for chasing down a no start problem. Bob 2 Share this post Link to post Share on other sites
c-series don 10,779 #10 Posted July 21, 2022 @mrharris12 Did you figure out the problem? I have a 418-C also and was wondering if you figured out what it was? Share this post Link to post Share on other sites
mrharris12 33 #11 Posted July 21, 2022 1 hour ago, c-series don said: @mrharris12 Did you figure out the problem? I have a 418-C also and was wondering if you figured out what it was? havent gone to troubleshoot quite yet, got the wiring diagram printed out and the steps from @Achto printed out. Hopefully will get around to doing that either tomorrow or this weekend. 3 Share this post Link to post Share on other sites
Handy Don 15,202 #12 Posted July 22, 2022 What @Achto said with one addition. Have the tractor in neutral and the wheels chocked when you do this sequence (in case it cranks or even starts!) 1 Share this post Link to post Share on other sites
mrharris12 33 #13 Posted July 23, 2022 On 7/21/2022 at 5:53 PM, c-series don said: @mrharris12 Did you figure out the problem? I have a 418-C also and was wondering if you figured out what it was? So I was tracing the wires and on the PTO switch I wasnt getting good connectivity. Come to find out the top switch (where the Tan and purple meet) the arm to engage contact was missing. So I am positive that has to be the issue. Now to find that switch 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #14 Posted July 24, 2022 Still available from Toro https://www.partstree.com/search/?type=part&term=111332 1 Share this post Link to post Share on other sites
