WHX?? 58,347 #26 Posted April 6, 2023 3 hours ago, rmaynard said: So, I don't know what if anything I accomplished by installing the ACR cam other than proving that it's easy The ACR cam is a God send Bob. Of all my tractors two don't have it. A 1045 and a 1055. If I told you to take one for a tool you wouldn't be able to start either without knowing the tricks. They lock right up on compression and no matter how tight that SG belt is the SG stalls out. This is when we see smoke coming out of an orginal type 70 Amp ig switch. A sure sign to lay off on it. One has to lay off the switch and the motor rolls backwards a tad. Then you hit the key again and they pop off. Of course this all changes if the motor is cold or hot and you are intimate with the carb settings. 1 1 Share this post Link to post Share on other sites
953 nut 70,325 #27 Posted April 6, 2023 11 hours ago, WHX?? said: The ACR cam is a God send Bob. Of all my tractors two don't have it. A 1045 and a 1055. None of my older engines (953 and 1055) have the ACR cam but the spark advance cam works well if the timing is right on the money. If it is too far advanced (gap to large) it kicks back. If it is retarded (gap too tight) starting is easy but no power. 1 1 Share this post Link to post Share on other sites
WHX?? 58,347 #28 Posted April 6, 2023 Point taken Richard ... more than likely why the 1045 kicks back. So if you had a SG motor ready for assembly on the bench and both style cams available which one would go in? Share this post Link to post Share on other sites
Handy Don 17,677 #29 Posted April 6, 2023 3 minutes ago, WHX?? said: Point taken Richard ... more than likely why the 1045 kicks back. So if you had a SG motor ready for assembly on the bench and both style cams available which one would go in? Great question! Share this post Link to post Share on other sites
WHX?? 58,347 #30 Posted April 6, 2023 5 minutes ago, Handy Don said: Great question! I thought so Don. When I was building the 1055 motor I had both and went with the advance cam. Mainly because that's what was in it. Hindsight being 20/20 I shoulda put in the ACR one. It may have meant dealing with tappet & valve length issues like Bob had but worth it? Share this post Link to post Share on other sites
squonk 48,324 #31 Posted April 6, 2023 Compression release every time. The 2 piece Spark Advance cam is a pain to install 2 Share this post Link to post Share on other sites
richmondred01 2,393 #32 Posted April 6, 2023 5 minutes ago, squonk said: Compression release every time. The 2 piece Spark Advance cam is a pain to install Yes they are a pain. You need two hands and 12 fingers. I’ve got two hands but only 7 fingers that work. 1 Share this post Link to post Share on other sites
WHX?? 58,347 #33 Posted April 6, 2023 Interesting the 1054 I just picked up from @Shynon has a weird starting quirk. It rolls over very easy so obviously a ACR cam. Starts to run at very low rpm like it's still rolling on the SG but the start button is released. After about 10 seconds you can hear/feel the ACR flip and off she goes. Share this post Link to post Share on other sites
rmaynard 17,642 #34 Posted April 6, 2023 And my fat fingers always seem to get in the way of each other. Share this post Link to post Share on other sites
rmaynard 17,642 #35 Posted April 6, 2023 (edited) 2 minutes ago, WHX?? said: Interesting the 1054 I just picked up from @Shynon has a weird starting quirk. It rolls over very easy so obviously a ACR cam. Starts to run at very low rpm like it's still rolling on the SG but the start button is released. After about 10 seconds you can hear/feel the ACR flip and off she goes. I think maybe the idle is set too low? ACR doesn't kick out until 600 RPM. Edited April 6, 2023 by rmaynard Share this post Link to post Share on other sites
squonk 48,324 #36 Posted April 6, 2023 59 minutes ago, WHX?? said: Interesting the 1054 I just picked up from @Shynon has a weird starting quirk. It rolls over very easy so obviously a ACR cam. Starts to run at very low rpm like it's still rolling on the SG but the start button is released. After about 10 seconds you can hear/feel the ACR flip and off she goes. Sounds like the weights that operating the ACR lever are hanging up or maybe the spring is broken Share this post Link to post Share on other sites
