JoeM 10,294 #1 Posted June 30, 2022 Picked this up today, a rusted hunk. Freed up in 15 minutes, was not as bad as it looked. An old friend gave it to me. New they are 2K + 9 4 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #2 Posted June 30, 2022 Nice , that is a heavy sucker . Two men and a boy to lift it. 3 Share this post Link to post Share on other sites
ebinmaine 80,760 #3 Posted June 30, 2022 Interesting piece. Any particular plans for it? 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,594 #4 Posted June 30, 2022 30 minutes ago, ebinmaine said: Interesting piece. Any particular plans for it? I’m guessing he’s gonna press arbors with it… Cool old tool!!! 2 8 Share this post Link to post Share on other sites
ri702bill 13,085 #5 Posted June 30, 2022 Say it like a Kennedy - Abah !! Seroiusly a 5 ton press is only limited by what is is bolted to and the physical willingness of the person working the handle.I have used many of these over the years - is there a hole at the bottom of the ram to insert tools?? 2 1 Share this post Link to post Share on other sites
JoeM 10,294 #6 Posted July 1, 2022 2 hours ago, ebinmaine said: Any particular plans for it? Got a spot on the heavy bench picked out. I can press in races, and might get a broach set. I think it just looks cool! Plus it weighs more than me! 1 hour ago, ri702bill said: is there a hole at the bottom of the ram to insert tools? IDK have to check eye! 4 Share this post Link to post Share on other sites
tunahead72 2,662 #7 Posted July 1, 2022 @JoeM I know absolutely nothing about arbor presses, but Royersford Foundry & Machine is still in business, located now in Phoenixville PA, less than 2 miles from my house. I'm sure you can get all the information you want from their website, but if there's anything I can do to help you get parts, let me know. I head out your way several times during the year, out the turnpike and down I-81, we can meet somewhere halfway if you want. 3 Share this post Link to post Share on other sites
adsm08 5,151 #8 Posted July 1, 2022 2 hours ago, ri702bill said: Say it like a Kennedy - Abah !! Seroiusly a 5 ton press is only limited by what is is bolted to and the physical willingness of the person working the handle.I have used many of these over the years - is there a hole at the bottom of the ram to insert tools?? I've had a wheel bearing or two withstand the full wrath of a 12 ton. That's why I have a 20T. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #9 Posted July 1, 2022 Found this in catalog 75B http://vintagemachinery.org/mfgindex/detail.aspx?id=710&tab=3 1 Share this post Link to post Share on other sites
JoeM 10,294 #10 Posted July 1, 2022 4 hours ago, tunahead72 said: if there's anything I can do to help you get parts, let me know. I head out your way several times during the year, out the turnpike and down I-81, we can meet somewhere halfway if you want Awesome! Thanks 1 Share this post Link to post Share on other sites
ri702bill 13,085 #11 Posted July 1, 2022 (edited) 6 hours ago, gwest_ca said: Found this in catalog 75B The simple ratchet allows you to set the height of the ram with the handwheel and the lever handle stays stationary. Note the the handle is both smaller in diameter and somewhat shorter than the standard model that has the thumbscrew to allow you to adjust the lever length. This is to protect the ratchet mechanism - do not use a cheater bar or pipe to extend the handle. I see that the handle is bent where it goes into the casting - a little late for my advise... Bill Edited July 1, 2022 by ri702bill 1 Share this post Link to post Share on other sites
JoeM 10,294 #12 Posted July 1, 2022 (edited) 2 hours ago, ri702bill said: I see that the handle is bent where it goes into the casting I thought the same but it is bent the same on both ends. One troubling point and I am not sure it was hurt but the top of the square ram looks like it was hit with a hammer. No doubt it was abused a bit. Edited July 1, 2022 by JoeM 1 Share this post Link to post Share on other sites
ri702bill 13,085 #13 Posted July 1, 2022 (edited) That would have been from the efforts of a mis-guided Tag Team!! It always amazes me when someone will NOT learn the limitations of a good tool and do something out of a 3 Stooges Short movie to "improve " the capability...I have no kindness or use for such folks... Edited July 1, 2022 by ri702bill 1 Share this post Link to post Share on other sites
