Similar Content
By BrianKoch
Hello gentleman,
Problem: will not crank on its own, will crank with jump box—but still not fire
Recent things I did prior to this issue: cleaned fuel filter, replaced battery cables, replaced cable from ignition to starter
I have my test light out and am probing around.
There is no power at ignition/magneto wire or the ignition/starter wire
There is power everywhere else
By Slightly Discombobulated
I need some help. I picked up a 1968 electro 12 (1-7235) that I'm assuming is an early model built with a leftover 67 engine because the engine patina matches the tractor and it has an external generator/starter instead of the magneto. It's a k301S-4712B. I bought it knowing that the engine turns freely and that it had no spark. Being 52 years old I figured it deserved some fresh ignition parts so I replaced the coil, condenser, points (cleaned and set to .020), spark plug (.035), and plug wire, and I still cannot get a spark at the plug or through my spark plug tester. It turns over okay and I've got 12 volts to the positive terminal on the coil. It's been many years since last worked on this type of ignition system and I'm stumped. I would appreciate any input/suggestions you might have. If it were something newer I'd suspect a safety switch but I can't see that this has any.
By firemanironman
I picked up a wheel horse and I am having trouble finding the connection for this wire. I have no spark and have searched for the placement of this wire within the distance of its length...any ideas?...can't seem to paste the picture....
By 12 hp Kohler
Picked up a charger 12 at auction yesterday. Put a battery, new fuel lines and a new spark pug in and it fired right up. Hydro seems to work pretty well, lever needs some adjustments but other wise it seems okay. I would like to put fresh transmission fluid in and a new filter on yet and then it should be good to go. I'm gonna start using this for plowing instead of my 753, i tried it out today and it seemed to work pretty well. The paint on the fenders and hood is a little off but it wont be hard to fix that.
By RJ Hamner
We brought my next project home last night. I think I am going to need a BIGGER shed real soon
