GaryRat 31 #26 Posted August 9, 2022 (edited) As stated in my last post, the tractor is now kaput until I get the connecting rod replaced. If you read my posts, I do mention that I found that the blades were on backwards initially and corrected that. When it was running, the right blade spun ccw and the left blade cw which I am guessing aided in discharging cut grass to the rear of the deck which is basically open. The cutting edges are the leading edges. Edited August 9, 2022 by GaryRat Share this post Link to post Share on other sites
Handy Don 17,562 #27 Posted August 9, 2022 1 hour ago, Rick3478 said: ... From what perspective is your rotation? Looking down from the top, shouldn't the left side turn counter and the right side be clockwise? Any chance you just have the blades on the wrong sides? Looking down (from the seat, if that's easier), this is correct. A common issue with these mowers is the grass pushed forward and building up at the top front center of the shell, not being cleaned, and rusting through right at the mount for the front anti-scalp roller. Share this post Link to post Share on other sites
Rick3478 470 #28 Posted August 9, 2022 1 hour ago, GaryRat said: As stated in my last post, the tractor is now kaput until I get the connecting rod replaced. If you read my posts, I do mention that I found that the blades were on backwards initially and corrected that. When it was running, the right blade spun ccw and the left blade cw which I am guessing aided in discharging cut grass to the rear of the deck which is basically open. The cutting edges are the leading edges. You said they were upside down, but your description of rotation direction sounds backwards, which could have led you to put the blades on the wrong sides, so I have to ask "are you sure?" And I assume (or hope) you will get it runnning again. Share this post Link to post Share on other sites
