Docwheelhorse 2,739 #1 Posted June 14, 2022 Hello All, I have a C160-8 that ended up with a hydro drive pulley somewhere in its past or a complete 16 out of a hydro. Well... I have a C160 Hydro with a knocking wreck of a motor and decided to pull this engine out to put in the hydro and swap a Mag 16 into the C160 at a friend's request. He wanted a C160 but doesn't like the K versus the Mag. In the past I've swapped Mags into Bs but the exhaust / muffler is too big and hood wouldn't shut. It was a pleasant surprise to see a Mag fit like a glove into a C! I'll have to measure but it's almost obvious the C hood is taller than the B. The 416-8 donor tractor was / is completly beat... the 2nd interesting event was that all I did was connect a battery, jam the fuel line into a can of fresh fuel and tickle it with carb clean. It started and runs great... been sitting for YEARS See you at show!! Tony 20220614_111050.mp4 20220614_111050.mp4 2 10 1 Share this post Link to post Share on other sites
ebinmaine 71,853 #2 Posted June 15, 2022 25 minutes ago, Docwheelhorse said: I'll have to measure but it's almost obvious the C hood is taller than the B. Tony check the hood hinges carefully when you look at the sheet metal. Seems to me the 74/75 B with it's "mid length" frame used the same hood but different hinges. It would make sense that a C hood may set a bit higher but I wasn't aware of a height change. Is your C series receiving the engine originally a Tecumseh engine tractor? The one you brought up and the one I bought both have VERY tall hood hinges to help clear the overhead valve engine. 2 Share this post Link to post Share on other sites
SylvanLakeWH 28,094 #3 Posted June 15, 2022 @Docwheelhorse perhaps a lottery ticket or two would be in order…? Nice save!!! 2 Share this post Link to post Share on other sites
Docwheelhorse 2,739 #4 Posted June 15, 2022 10 minutes ago, ebinmaine said: Tony check the hood hinges carefully when you look at the sheet metal. Seems to me the 74/75 B with it's "mid length" frame used the same hood but different hinges. It would make sense that a C hood may set a bit higher but I wasn't aware of a height change. Is your C series receiving the engine originally a Tecumseh engine tractor? The one you brought up and the one I bought both have VERY tall hood hinges to help clear the overhead valve engine. Interesting... Ill have to run the ID number and see if this C was one of the Tecumseh OHV ones 1 Share this post Link to post Share on other sites
ebinmaine 71,853 #5 Posted June 15, 2022 4 minutes ago, Docwheelhorse said: Interesting... Ill have to run the ID number and see if this C was one of the Tecumseh OHV ones IIFF it was... And IIFF you don't want the tag... Lemme know. The one I bought has no tag. 1 Share this post Link to post Share on other sites
Docwheelhorse 2,739 #6 Posted June 15, 2022 1 minute ago, ebinmaine said: IIFF it was... And IIFF you don't want the tag... Lemme know. The one I bought has no tag. Isnt VIN tag manipulation a felony? Lol 6 Share this post Link to post Share on other sites
ebinmaine 71,853 #7 Posted June 15, 2022 1 minute ago, Docwheelhorse said: Isnt VIN tag manipulation a felony? Lol I believe it is. Let's not be advertising this extreme number swapping to the authorities ehh??? 2 1 Share this post Link to post Share on other sites
Docwheelhorse 2,739 #8 Posted June 15, 2022 5 minutes ago, ebinmaine said: IIFF it was... And IIFF you don't want the tag... Lemme know. The one I bought has no tag. Here's a pic of tag... de-code it and let me know , I'll drill the rivets and bring to show if it's legit. Neither I nor my friend would care if the tag was gone 1 Share this post Link to post Share on other sites
ebinmaine 71,853 #10 Posted June 15, 2022 Looks like that's a 1 0385 9 That IS a Tecumseh engine tractor. I won't be at the Big Show.... If you'd kindly mail that to me I'd be happy to send a bit of compensation. 3 Share this post Link to post Share on other sites
ebinmaine 71,853 #11 Posted June 15, 2022 I find it interesting that you'd get your hands on TWO of those Tecumsehorse as uncommon as they're claimed to be. 1 1 Share this post Link to post Share on other sites
Docwheelhorse 2,739 #12 Posted June 15, 2022 6 minutes ago, ebinmaine said: I find it interesting that you'd get your hands on TWO of those Tecumsehorse as uncommon as they're claimed to be. Kinda like there's only "225" 520-8s... but I've seen 1,437,763 of them.... 6 Share this post Link to post Share on other sites
Pullstart 65,821 #13 Posted June 15, 2022 1 hour ago, Docwheelhorse said: Kinda like there's only "225" 520-8s... but I've seen 1,437,763 of them.... Especially after I got my hands on one… then they popped up everywhere! 3 Share this post Link to post Share on other sites
Maxwell-8 4,367 #14 Posted June 15, 2022 I had trouble fitting a M16 in my C141 LOL 5 1 1 Share this post Link to post Share on other sites
JoeM 8,169 #15 Posted June 15, 2022 I am pretty sure we raised the hood 3/4 on this c120 for the mag 10. Original was an HH120 Tecky Flat Head. 2 Share this post Link to post Share on other sites
squonk 43,361 #16 Posted June 15, 2022 10 hours ago, Docwheelhorse said: Isnt VIN tag manipulation a felony? Lol He's in "Maine" 1 2 Share this post Link to post Share on other sites
peter lena 9,190 #17 Posted June 15, 2022 @Docwheelhorse terrific swap on that , boy I would love to do the recovery / wake up on that engine ! I do it in stages from fuel to electric , grounding . go over every area . gallon jugs of fuel and treatment , hot flush oil change , add all my improvements that I have on my engines. looking at that , with a bib on , sweet , pete 1 1 Share this post Link to post Share on other sites
Docwheelhorse 2,739 #18 Posted June 18, 2022 UPDATE... 6/17/22 I've got about 30 hrs into this swap... starter, puked, the spare was junk... pulled a 3rd... solenoid worked then puked... it has been busting stones. But I kept going and it runs sweet, tomorrow a deck and a "field trial" Happy Weekend !!! See you next week at the BIG SHOW!!! 20220617_193459.mp4 2 1 Share this post Link to post Share on other sites
ebinmaine 71,853 #19 Posted June 18, 2022 30 minutes ago, Docwheelhorse said: runs sweet Good to hear Man! Any chance that ID plate will "fall off"? 😀 1 Share this post Link to post Share on other sites
Docwheelhorse 2,739 #20 Posted June 18, 2022 41 minutes ago, ebinmaine said: Good to hear Man! Any chance that ID plate will "fall off"? 😀 I've thought about it and have decided to leave it on... that way there's a story behind the tractor and a way to prove it. Isn't there someone doing reproductions of these tags that could bang you out one 2 Share this post Link to post Share on other sites
ebinmaine 71,853 #21 Posted June 18, 2022 24 minutes ago, Docwheelhorse said: I've thought about it and have decided to leave it on... that way there's a story behind the tractor and a way to prove it. Isn't there someone doing reproductions of these tags that could bang you out one I like that logic. Good to have it there. Gives provenance. Reproduction?? Wasn't aware of those tags being done... That'd be neat. Any thoughts where to look? 1 Share this post Link to post Share on other sites
Thor27 832 #22 Posted June 18, 2022 On 6/14/2022 at 5:56 PM, ebinmaine said: That IS a Tecumseh engine tractor. You posted that just in time to stop me from robbing a c120 parts tractor hood for my 312H! thanks. 3 Share this post Link to post Share on other sites
