gt14rider 1,281 #1 Posted June 13, 2022 Hi all, does anyone know if a rear mount grader blade fit on a 856, the grader blade is a 07- 50Bm02 Share this post Link to post Share on other sites
rjg854 13,404 #2 Posted June 13, 2022 I believe it should, I'm not familiar with that exact model, but I've had other models that worked fine. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,510 #3 Posted June 13, 2022 The grader blade 07-50BM02 uses rear axle quick-hitch brackets that mount under the rear axle housings. Same hitch for dozer blade. You may need to use these rear hitch parts. The 856 uses dozer that connects to rear axle quick-hitch that mounts to the front and below the rear axle housings and these may not work with the later grader blade. 1 Share this post Link to post Share on other sites
gt14rider 1,281 #4 Posted June 13, 2022 Like these? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,510 #5 Posted June 13, 2022 Those are the later style that mount under the axle housing. Look at BD-4264A here for the older style ahead of the axle housing. https://www.partstree.com/models/bd-4264a-toro-42-snow-dozer-blade-1965/ Share this post Link to post Share on other sites
gt14rider 1,281 #6 Posted June 13, 2022 Thank you, got to get mower deck off and see were she sits. Thanks again for the info. Share this post Link to post Share on other sites
