RonnieB2nd 33 #1 Posted June 11, 2022 It looks really simple on YouTube. The guy attached the box then the belt to deck pulley then the closet pulley groove to the engine. What am I missing? Share this post Link to post Share on other sites
Jeff-C175 7,211 #2 Posted June 11, 2022 5 minutes ago, RonnieB2nd said: What am I missing? Dunno? Are you having some sort of trouble changing the belt? Can you describe the issue? 1 Share this post Link to post Share on other sites
peter lena 10,013 #3 Posted June 11, 2022 @RonnieB2nd thats very easy , take advantage of frame mount , for nut removal on belt guard . open end wrench , easy . replace belt as you remove belt , so its exactly as it was , how do pulleys sound or move ? is it rusty any where ? how about lubing , adjustment knob threads ? check out pto rod adjustment trundle at lever point , sloppy fit ? washer it up to firm and grease related areas . just some regular detailing on that set up , pete Share this post Link to post Share on other sites
