rmaynard 17,423 #1 Posted June 10, 2022 The 704 that I am working on has a lot of slop in the steering. Among other things, I have found that the fan gear rotates a bit on the lower shaft. This fan gear is fixed to the shaft with two roll pins, one is 1/4" with a smaller pin inside of it. Both pins are in good condition, so I assume that the hole in the shaft is slightly out of round, allowing for the movement. What is the recommended fix for this? Should I have the gear welded to the shaft or would I be better off putting a bolt through the gear and torquing it down? Share this post Link to post Share on other sites
ri702bill 12,475 #2 Posted June 10, 2022 (edited) Neither - Try a coiled (aka Spirol) pin first - If the hole(s) are so wallowed out, go up to 5/16". Spiral wound pins cover a wider range of hole size than a split pin and have at least 2X the radial holding power. They work. Edited June 10, 2022 by ri702bill 2 1 Share this post Link to post Share on other sites
rmaynard 17,423 #3 Posted June 10, 2022 Nothing appears wallowed. Does the larger pin still require a smaller pin inside it? Share this post Link to post Share on other sites
squonk 47,381 #4 Posted June 10, 2022 (edited) Service bulletin. I did this on my 704. Worked great and easy to do. did the fan gear and both spindles. @rjg854 just did his 1045 WH61-90 #049 Steering roll pin Orig.pdf Edited June 10, 2022 by squonk 1 1 Share this post Link to post Share on other sites
rmaynard 17,423 #5 Posted June 10, 2022 1 hour ago, squonk said: Service bulletin. I did this on my 704. Worked great and easy to do. did the fan gear and both spindles. @rjg854 just did his 1045 WH61-90 #049 Steering roll pin Orig.pdf 233.49 kB · 3 downloads Thanks Mike. Looks like this will work. Share this post Link to post Share on other sites
JoeM 10,093 #6 Posted June 10, 2022 2 hours ago, rmaynard said: gear welded to the shaft I have welded those and used a stainless steel welding rod. Worked real good. But it sounds like Mike has the best fix. Share this post Link to post Share on other sites
adsm08 4,790 #7 Posted June 10, 2022 25 minutes ago, JoeM said: I have welded those and used a stainless steel welding rod. Worked real good. But it sounds like Mike has the best fix. I dunno, I'm about ready to weld mine. The draw back to welding them is that the fan has to be removed from the shaft to remove the assembly from the tractor. On the other hand, the only reason I have ever found to disassemble said assembly is to remove it from the tractor, and the only reason I have ever found for that is to work on it when it gets sloppy. 3 Share this post Link to post Share on other sites
rmaynard 17,423 #8 Posted June 11, 2022 3 hours ago, adsm08 said: The draw back to welding them is that the fan has to be removed from the shaft to remove the assembly from the tractor. i removed my lower shaft and fan by taking the four bolts out that mount the engine and sliding the engine forward. Hardest part was taking the steering wheel shaft out. The collar was pretty stuck after 58 years. After removing the shaft, the rest was easy. 1 Share this post Link to post Share on other sites
adsm08 4,790 #9 Posted June 11, 2022 17 minutes ago, rmaynard said: i removed my lower shaft and fan by taking the four bolts out that mount the engine and sliding the engine forward. Hardest part was taking the steering wheel shaft out. The collar was pretty stuck after 58 years. After removing the shaft, the rest was easy. That may well be possible. I had issues getting things to clear the frame, and at the time engine removal of any degree was a bit more effort than I was willing to put into the job. Share this post Link to post Share on other sites
Handy Don 16,944 #10 Posted June 11, 2022 4 hours ago, adsm08 said: I dunno, I'm about ready to weld mine. The draw back to welding them is that the fan has to be removed from the shaft to remove the assembly from the tractor. On the other hand, the only reason I have ever found to disassemble said assembly is to remove it from the tractor, and the only reason I have ever found for that is to work on it when it gets sloppy. I was already doing a full frame-off refresh due to a cracked F plate and numerous other issues. I had the frame on the lift table upside down and a simple twist of the sector gear and in it went. I'd also added a front bearing for the lower steering shaft since it was right there and easy to do. 3 Share this post Link to post Share on other sites
rmaynard 17,423 #11 Posted June 18, 2022 On 6/10/2022 at 3:46 PM, squonk said: Service bulletin. I did this on my 704. Worked great and easy to do. did the fan gear and both spindles. @rjg854 just did his 1045 WH61-90 #049 Steering roll pin Orig.pdf 233.49 kB · 32 downloads Followed bulletin to the letter. Worked perfect. Thanks Mike. 3 Share this post Link to post Share on other sites
