Jallen7773 0 #1 Posted June 5, 2022 When my wire from the magneto is connected to the ignition switch, no spark at the plug. If my wire from the magneto is not connected, it starts fine, but won't switch off. Any suggestions? Share this post Link to post Share on other sites
Blasterdad 3,163 #2 Posted June 5, 2022 5 minutes ago, Jallen7773 said: When my wire from the magneto is connected to the ignition switch, no spark at the plug. If my wire from the magneto is not connected, it starts fine, but won't switch off. Any suggestions? Sounds like a bad ignition switch, easy fix. 2 1 Share this post Link to post Share on other sites
Blasterdad 3,163 #3 Posted June 5, 2022 It would help us too if you tell us what model tractor you have.... Share this post Link to post Share on other sites
8ntruck 8,668 #4 Posted June 5, 2022 (edited) I believe that the wire between the mag and ignition switch is the ground wire for the mag. Connect it to ground, the engine shouts off. Not connected to ground, the mag will make spark. I think the ignition switch grounds this wire in the off position. Do not put 12v on that wire. Magic smoke will come out of the mag, and it will quit working. to the forum. You have found a good source of help for your Wheel Horse. Edited June 5, 2022 by 8ntruck 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #5 Posted June 5, 2022 (edited) 23 minutes ago, Blasterdad said: Sounds like a bad ignition switch, easy fix. Possibly the WRONG ignition switch too. Is this tractor one that you've had for some time or is it new to you? @Jallen7773 Edited June 5, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
953 nut 64,647 #6 Posted June 5, 2022 9 hours ago, Blasterdad said: bad ignition switch, 9 hours ago, 8ntruck said: the wire between the mag and ignition switch is the ground wire for the mag. Connect it to ground, the engine shouts off. 9 hours ago, Jeff-C175 said: Possibly the WRONG ignition switch too @Jallen7773, Is this a tractor you have owned for a while and just started actin up? Has anything in the wiring been changed? Do you own or have access to an Ohm Meter? Please let us know what model your is and we can help you eliminate this problem. 1 Share this post Link to post Share on other sites
