Mike C160 251 #1 Posted June 3, 2022 Greetings. Well, I had asked what drive belt to put on my 1977 C160. I was told to check the parts manual. But I couldnt find a 1977. I was told a 76 would be fine. That I found And the drive belt pt number was 7478 which is 84 x 5/8ths. However its too big. Its too long and 5/8ths seems also too big. Does anyone know what the correct belt for this unit is? I would appreciate. Cheers Share this post Link to post Share on other sites
squonk 45,590 #2 Posted June 3, 2022 5/8" is correct. is this Auto or 8 spd? Share this post Link to post Share on other sites
Mike C160 251 #3 Posted June 3, 2022 Just now, squonk said: 5/8" is correct. is this Auto or 8 spd? Sorry its auto Share this post Link to post Share on other sites
squonk 45,590 #4 Posted June 3, 2022 Belt is 7478 which is 5/8 x 84" Check the belt to make sure it has the right # on it and also measure it. Mistakes do happen. Can you post a picture of the belt on the tractor so we can see what's going on? https://www.partstree.com/models/71-16ks02-c-160-toro-lawn-tractor-1977/ 1 Share this post Link to post Share on other sites
Mike C160 251 #5 Posted June 3, 2022 12 minutes ago, squonk said: Belt is 7478 which is 5/8 x 84" Check the belt to make sure it has the right # on it and also measure it. Mistakes do happen. Can you post a picture of the belt on the tractor so we can see what's going on? https://www.partstree.com/models/71-16ks02-c-160-toro-lawn-tractor-1977/ Grrrr Yup They sent me home with a B84. But when you look at the REAL specs, its 87 inches long. Thanks. 2 steps forward 1 step backwards. 1 Share this post Link to post Share on other sites
squonk 45,590 #6 Posted June 3, 2022 You want a 5L840. Do not use a B belt. If you have a Napa near by get a 5L840W 1 Share this post Link to post Share on other sites
Mike C160 251 #7 Posted June 3, 2022 2 minutes ago, squonk said: You want a 5L840. Do not use a B belt. If you have a Napa near by get a 5L840W Yup. Thanks. Now my tractor is all apart and I cant reach them till Monday. Welcome to my world Share this post Link to post Share on other sites
Mike C160 251 #8 Posted June 3, 2022 @squonk Well, the new idler pulley is on All dressed up and no belt to go. I got the lift cable and rocker shaft to install along with an oil and filter for the rear end. I suppose I'll quit my whining and get back to work. Cheers 1 Share this post Link to post Share on other sites
squonk 45,590 #9 Posted June 3, 2022 13 minutes ago, Mike C160 said: Yup. Thanks. Now my tractor is all apart and I cant reach them till Monday. Welcome to my world No Napa ,Tractor Supply or Rural King near you? Share this post Link to post Share on other sites
Mike C160 251 #10 Posted June 3, 2022 20 minutes ago, squonk said: No Napa ,Tractor Supply or Rural King near you? Im kind of remote so our napa is small and likely wont have this in stock Im a little let down right now. I just drained the oil from the rear end and small pieces of bearing cages came out. 1 Share this post Link to post Share on other sites
Mike C160 251 #11 Posted June 3, 2022 (edited) @squonk Any idea where this could be from? Differential? Or hydro unit? Common place failure? It runs and drives fine..... Cheers Edited June 3, 2022 by Mike C160 Share this post Link to post Share on other sites
