Wilsonrl48747 0 #1 Posted July 5, 2009 Just bought a rear discharge 36 in deck and went to grease the spindles, and 2 of the 3 wont allow me to pump grease into the zerks. I took the zerks off and cleaned them out, used wire to push the ball in and it seems to open, but when I put the zerks back on, same thing, it wont let me pump grease in. Any advice on what to check? Thanks Share this post Link to post Share on other sites
TJ 184 #2 Posted July 5, 2009 Try pulling the zerk, and taking a small screwdriver, insert it into the hole on the spindle, wiggle it around and push out any hardened grease. It sounds obscene, but it has worked for me in the past. Tom Share this post Link to post Share on other sites
WheelHorse_of_course 101 #3 Posted July 5, 2009 And test if it passes grease before you put it back on If it doesn't you may want to try soaking it in Kerosene or something similar. Best of luck Share this post Link to post Share on other sites
