Scott with a C105 2 #1 Posted May 28, 2022 My C105 had a 42" side discharge deck and it is pretty worn out so I picked up another 42" deck. Seems the old deck had a 4.5" drive / center pulley and the new deck has a 3.5" drive / center pulley. I ended up getting a smaller belt but the new deck seems to bog down in thick grass and it makes a lot of noise. Should I try and move the old spindle or pulley to the new deck or should I try to run belt on the outside grove on the PTO? I think the blades are going too fast with the smaller pulley. Share this post Link to post Share on other sites
daveoman1966 3,881 #2 Posted May 28, 2022 My guess: Presuming the center pulley is the correct one: Your 'new' deck drive pulley is mounted upside-down. This error is VERY typical and all you gotta do is flip it over so that the 4.5" side of the pulley is UP...and the narrower 3.5" side is down. 5 1 Share this post Link to post Share on other sites
Scott with a C105 2 #3 Posted May 28, 2022 (edited) Duplicate Edited May 28, 2022 by Scott with a C105 Share this post Link to post Share on other sites
Scott with a C105 2 #4 Posted May 28, 2022 I really didn't think of that, I'm sure that would cause some major blade speed problems along with the bogging down issue I'm having. Thanks.... 1 Share this post Link to post Share on other sites
daveoman1966 3,881 #5 Posted May 28, 2022 7 minutes ago, Scott with a C105 said: I really didn't think of that, I'm sure that would cause some major blade speed problems along with the bogging down issue I'm having. Thanks.... I have this pulley if needed. NOTE: the drive belt on the PTO MUST be on the inner 'V' for the deck to work right. The factory OEM belt is 102742 (94-2501 new #) 1 Share this post Link to post Share on other sites
Scott with a C105 2 #7 Posted May 30, 2022 Well that fixed it, stupid pulley on the new deck was upside down. Who does that? I had to hit it with some penetrating oil and pry up to get it to come off. All is good now. Thanks... 1 Share this post Link to post Share on other sites
