OutdoorEnvy 1,807 #1 Posted May 27, 2022 Hey folks so what's the trick to removing the oil seal on the brake shaft that is metal on the outside of the seal? Seems like you would have drill into it but that doesn't sound like a great idea with shavings, etc. So wanted to check with the experts before attempting anything. For reference this is a 74 C-100 8 speed. 1 Share this post Link to post Share on other sites
ebinmaine 77,507 #2 Posted May 27, 2022 You can carefully drill a small hole then insert a sheet metal screw. Use vise grips to grab the sheet metal screw. I've tried that and had mediocre success with it. I have better success with a somewhat barbaric method of basically crushing the seal Pat and angle until it will spin on the shaft and then removing it with a screwdriver. 1 1 Share this post Link to post Share on other sites
lynnmor 8,644 #3 Posted May 27, 2022 2 minutes ago, OutdoorEnvy said: Hey folks so what's the trick to removing the oil seal on the brake shaft that is metal on the outside of the seal? Seems like you would have drill into it but that doesn't sound like a great idea with shavings, etc. So wanted to check with the experts before attempting anything. If you are concerned about shavings, punch a hole with a sharp center punch that has more taper than most, think ice pick. 4 2 1 Share this post Link to post Share on other sites
peter lena 9,779 #4 Posted May 27, 2022 @OutdoorEnvy how about a PACKING PULLER , as the puller and a needle punch for the hole ? pete 2 1 Share this post Link to post Share on other sites
stevasaurus 23,619 #5 Posted May 27, 2022 It will be the same process...no drill needed. You want something small enough to get in between the metal of the seal and the shaft...something like this. This is a Carter Pin Puller. An ice pick with a bent point will also work. Pry and pull out. 1 1 1 Share this post Link to post Share on other sites
OutdoorEnvy 1,807 #6 Posted May 27, 2022 Thanks for the help all! It's out. Hammered in a pick tool then used one similar to what @stevasaurus suggested to pry it out. 1 1 Share this post Link to post Share on other sites
peter lena 9,779 #7 Posted May 27, 2022 @Handy Don many years servicing tank drive " stuffing boxes " at tank change over time , always used those packing pullers , when I first encountered w/h axel seals , it was a no brainer , like it was made for it . a fine pin punch just a tiny hole , screw in the puller , you are solid for a mechanical pull . easy , pete 1 Share this post Link to post Share on other sites
ri702bill 11,346 #8 Posted May 27, 2022 OK - seems that the removal process is well covered - REASSEMBLY - the seal needs to be square to the bore prior to insertion. I have had good sucess using the brake drum WITHOUT the woodruff key as a flat driving surface. Put cellophane tape over the empty keyway on the shaft to prevent damaging the seal and apply a spray or liquid lube to the shaft & seal - work it onto the shaft past it - remove the tape, use the drum as a driver, along with a deep socket to fit over the shaft - easy does it - tap it home. 3 Share this post Link to post Share on other sites
Horse Newbie 7,402 #9 Posted May 31, 2022 If I recall correctly, the brake shaft seal is the easiest of the brake shaft seal and the transmission input shaft seal… if you are gonna replace the transmission input shaft seal, it is a booger of a little thing. I trashed 2 before I took some advice on here and flipped it around backwards. When I did that, I had a little better results. It still did not go in perfect, but it will do. I also put some RTV sealant around the hole, and that helped too. The thing was the metal kept getting caught on the housing… Share this post Link to post Share on other sites
