S416-8 399 #76 Posted June 6, 2022 (edited) that is the lift bar for the mower deck. The 416 had it as one part. One this one there is the part that is broken in the pic and then the shaft that attaches it to the tractor is separate. Found the image on the internet... now to look for the part. found this link digging on the site here Edited June 6, 2022 by S416-8 link added 1 Share this post Link to post Share on other sites
953 nut 69,377 #77 Posted June 6, 2022 1 hour ago, S416-8 said: . now to look for the part. Give Lincoln a call at A to Z Tractor Parts, good guy to deal with. https://a-ztractor.com/ 1 Share this post Link to post Share on other sites
S416-8 399 #78 Posted June 6, 2022 (edited) Thanks.. like having the "whole" part but until then grabbed the welder and welded it all back up. The bar was bent where it broke so beefed it up as well. All this for a 60" deck that I want to swap for a 42 so I can get through the gates went straight to the site and it is there.. awesome and thanks.. will see if they have the other things I need Edited June 6, 2022 by S416-8 1 Share this post Link to post Share on other sites
S416-8 399 #79 Posted June 8, 2022 The 520 is alive again. Turns out that there was a bad ground.. it's all cleaned, new oil changes, plugs etc.. thanks for the tips.. post come pics when it is all together again 1 Share this post Link to post Share on other sites
