Lane Ranger 12,094 #51 Posted May 18, 2022 1 hour ago, dmoore said: Okay that's your tractor Lane Ranger wow! She is sure sharp I'd like the cleat tires on the back but I don't think I could do clean on the front as well I don't know maybe just me the tri ribs are a good alternative also. You can use 4.000 x 8. Or 3.50 x 8 tri ribs and they both will look good. I put a pair of 3.50 on one of my RJs as they look better to scale smaller! 1 Share this post Link to post Share on other sites
dmoore 1,042 #52 Posted May 18, 2022 Great info LR! I love your lil tractor! I have some time to mull it all over, hell I just got her running this afternoon! And video to prove it I didn't have an electrical problem, key switch etc. It was the fuel pump which was not letting fuel pass through. I took it off and opened her up to the sight of varnished, crusty fuel. My guess is as long as I was cranking it it produced enough vacuum to keep the engine running, make sense? 3 Share this post Link to post Share on other sites
dmoore 1,042 #53 Posted May 18, 2022 (edited) . Edited May 18, 2022 by dmoore duplicate Share this post Link to post Share on other sites
dmoore 1,042 #54 Posted May 18, 2022 (edited) My Cummins is running in the background... 20220517_194240.mp4 Edited May 18, 2022 by dmoore 2 1 Share this post Link to post Share on other sites
dmoore 1,042 #55 Posted May 18, 2022 That was before I removed the fuel pump and cleaned it up. Let's see if I can upload the vid where I got it to run. 2 Share this post Link to post Share on other sites
dmoore 1,042 #56 Posted May 18, 2022 20220518_135258.mp4 3 3 Share this post Link to post Share on other sites
dmoore 1,042 #58 Posted May 18, 2022 Front tires are Goodyear 4.80 /4.00-8 Super Rib. 3 Share this post Link to post Share on other sites
dmoore 1,042 #59 Posted May 18, 2022 What do you guys think? Could these front tires be original? 1 Share this post Link to post Share on other sites
dmoore 1,042 #60 Posted May 18, 2022 (edited) I know the rear tires are not original. They are Carlisle Turf Savers 23 x 8.50 -12 Edited May 18, 2022 by dmoore 2 Share this post Link to post Share on other sites
Lane Ranger 12,094 #61 Posted May 19, 2022 2 hours ago, dmoore said: What do you guys think? Could these front tires be original? Yes most likely original. These Goodyears were used on the earlier Wheel Horses. I bought this new old stock set this year. 2 2 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #62 Posted May 19, 2022 2 minutes ago, Lane Ranger said: earlier Wheel Horses Do you know what year they started printing "Wheel Horse" on the tires? 1 Share this post Link to post Share on other sites
dmoore 1,042 #63 Posted May 19, 2022 19 minutes ago, Lane Ranger said: Yes most likely original. These Goodyears were used on the earlier Wheel Horses. I bought this new old stock set this year. Are there more? 1 Share this post Link to post Share on other sites
Lane Ranger 12,094 #64 Posted May 19, 2022 Not many out there that I know of still for sale. Share this post Link to post Share on other sites
76c12091520h 4,284 #65 Posted May 19, 2022 Fronts are the originals, mine has 'em too 2 Share this post Link to post Share on other sites
dmoore 1,042 #66 Posted May 19, 2022 Thanks Brian! Damn that's nice! And you use it Share this post Link to post Share on other sites
dmoore 1,042 #67 Posted May 19, 2022 White or Linen Beige? Share this post Link to post Share on other sites
dmoore 1,042 #68 Posted May 19, 2022 And I am dying to know, what are the two holes in hood stand just above key switch? Share this post Link to post Share on other sites
Handy Don 17,465 #69 Posted May 19, 2022 11 hours ago, dmoore said: And I am dying to know, what are the two holes in hood stand just above key switch? I'd guess that at one time that unit had he HY-1, -2, or -3 hydraulic accessory. Mine did and has the same holes. With that installed, it was impossible to reach the key, so that got relocated to a small box added to the left side of the hoodstand. On this unit, and mine, the key is back in the operator-facing part of the hoodstand. Share this post Link to post Share on other sites
dmoore 1,042 #70 Posted May 19, 2022 Don I bet you are correct. I keep forgetting about the hydraulics because of the tractor size! I believe there are a couple 854's here with that option. Thank you! Share this post Link to post Share on other sites
Handy Don 17,465 #71 Posted May 19, 2022 1 minute ago, dmoore said: Don I bet you are correct. I keep forgetting about the hydraulics because of the tractor size! I believe there are a couple 854's here with that option. Thank you! I'm almost positive that the guy I got mine from removed one just before offering the unit for sale. Ok with me as it was easily worth more by itself than I paid for the rest of the tractor and it was not something I wanted anyway. Share this post Link to post Share on other sites
dmoore 1,042 #72 Posted May 19, 2022 Gotcha, Yes, I have seen just the 2 smaller holes side by side and then I have seen the same two holes with a larger hole in between. Share this post Link to post Share on other sites
ri702bill 12,988 #73 Posted May 19, 2022 Here is a plcture of a HY-2 unit I have that was mounted on a 702. The 854 would have used a HY-3, but the pump mount and starter key relocation are the same. The pivot shaft is not the same. 1 1 Share this post Link to post Share on other sites
dmoore 1,042 #74 Posted May 19, 2022 There it is....nice pic Bill, thank you. Also Bill what size is that rear tire you have there and manufacturer? Thanks! Dave Share this post Link to post Share on other sites
Handy Don 17,465 #75 Posted May 19, 2022 38 minutes ago, dmoore said: There it is....nice pic Bill, thank you. Also Bill what size is that rear tire you have there and manufacturer? Thanks! Dave Those look like 6.00-12 Firestone All Purpose. @ri702bill? Share this post Link to post Share on other sites
