JoeM 9,340 #26 Posted May 13, 2022 Even a cloth belt would have a good bit of wear resistance. Sounds like slippage? A good spring cantilevered take up would keep it running proper tension and minimal slip. The one nice thing about a spring take up you can always put on a heavier spring or two. Cogged belts are a good candidate for this application, not so good if used as a clutching mechanism. They have lots of bite. They are noisy but you are running a chipper! You will never hear it. 3 Share this post Link to post Share on other sites
ebinmaine 76,157 #27 Posted May 14, 2022 2 hours ago, JoeM said: noisy but you are running a chipper Noisy?? I could park a jet next to this thing and barely hear it. 😂 2 Share this post Link to post Share on other sites
ebinmaine 76,157 #28 Posted May 14, 2022 2 hours ago, JoeM said: Sounds like slippage After reading the info from all you folks I'd agree. I'll get some tightenin' on it and see what we come up with. 1 Share this post Link to post Share on other sites
peter lena 9,598 #29 Posted May 14, 2022 @cafoose referring to your pulley function set up , found those angular drive points really cook those , very often small sealed bearings . that led my to the green stuff, realize it only enhances the issue . but whenever I can , pop off bearing side shields , and go lucas , x tra heavy duty . used to have whining pto mule drive bearings . all of my decks and drives , are lucas lubed ,560 drop point ,anti sling , grease. eliminate a failure , pete 2 1 Share this post Link to post Share on other sites
Snoopy11 5,723 #30 Posted May 14, 2022 On 5/13/2022 at 1:11 PM, squonk said: Rubber and cogged Sir yes sir. Right on the money. Don 1 Share this post Link to post Share on other sites
Snoopy11 5,723 #31 Posted May 14, 2022 16 hours ago, ebinmaine said: I'll get some tightenin' on it and see what we come up wit Sometime in the week, I would also recommend calling V-belt guys, and seeing if they have any recommendations for you. THEY ARE AWESOME!!! Also, Eric, what KIND of v-belt are you using, the blue ones from tractor stores? You might want to try a Bando belt in there, as opposed to an el-cheapo tractor store belt. V-belt guys knumber is : 1-800-213-9715 Don 3 1 Share this post Link to post Share on other sites
ebinmaine 76,157 #32 Posted May 14, 2022 2 hours ago, Snoopy11 said: Sometime in the week, I would also recommend calling V-belt guys, and seeing if they have any recommendations for you. THEY ARE AWESOME!!! Also, Eric, what KIND of v-belt are you using, the blue ones from tractor stores? You might want to try a Bando belt in there, as opposed to an el-cheapo tractor store belt. V-belt guys knumber is : 1-800-213-9715 Don Good advice and much appreciated. No cheap belts here. I used Gates green on this chipper. Might order a Gates rubber belt. I do have a couple (Brown/Browning?) Brand belts here too. 2 Share this post Link to post Share on other sites
Snoopy11 5,723 #33 Posted May 14, 2022 All of those sound like good belts, @ebinmaine... I do think rubber would be the first thing to try before getting too technical with it... Don 1 Share this post Link to post Share on other sites
ebinmaine 76,157 #34 Posted May 14, 2022 55 minutes ago, Snoopy11 said: rubber Can't get one til Tuesday or Wednesday. I'd like to see it up n runnin'.. tomorrow. 2 Share this post Link to post Share on other sites
Snoopy11 5,723 #35 Posted May 14, 2022 1 hour ago, ebinmaine said: I'd like to see it up n runnin'.. tomorrow. Can you pick one up at a car parts dealer, like O'reilly's...? My local O'reilly's has all kinds of rubber cogged belts... Don 1 Share this post Link to post Share on other sites
ebinmaine 76,157 #36 Posted May 14, 2022 9 minutes ago, Snoopy11 said: Can you pick one up at a car parts dealer, like O'reilly's...? My local O'reilly's has all kinds of rubber cogged belts... Don Nope. They have to order it from the local distribution center. And.... There ain't any "local" parts store on Sunday. 1 1 Share this post Link to post Share on other sites
Snoopy11 5,723 #37 Posted May 14, 2022 2 minutes ago, ebinmaine said: There ain't any "local" parts store on Sunday Geezeus bro... where do you live...? Don 2 Share this post Link to post Share on other sites
ebinmaine 76,157 #38 Posted May 14, 2022 32 minutes ago, Snoopy11 said: Geezeus bro... where do you live...? Don Trees n' mountains man..... ❤️ 3 Share this post Link to post Share on other sites
ebinmaine 76,157 #39 Posted May 15, 2022 Well folks I started addressing this beast again today. I tightened up one of the LH mounting bolts and replaced the other. Lifted the front of the machine a little with the floor jack and adjusted the belt tensioner pulley as tight as I could get it with my own lifting strength. @JoeM I think it was you mentioned about an inch of deflection in this belt. It's an 86" belt so there's 43" minus pulley diameters for flex. It's a pretty fair 1" I'd say. Took it out for a shakedown. Definitely better operating. I'll get some time on it and see how the belt wears. Ignore, wrong name: @Joe M 4 Share this post Link to post Share on other sites
JoeM 9,340 #40 Posted May 15, 2022 sure looks like it should run okay. 2 Share this post Link to post Share on other sites
Horse Newbie 7,400 #41 Posted May 15, 2022 On 5/13/2022 at 11:47 AM, JPWH said: That may work. Something like parachute cord or mule tape is what I use. That may work, but I hate packing my parachute back up… 2 Share this post Link to post Share on other sites
ebinmaine 76,157 #42 Posted May 15, 2022 1 hour ago, JoeM said: sure looks like it should run okay. Thanks. Them big tires make a Huge difference in capability of movement through the forest. The belt is... Better. I tightened it up for all I could lift. Deflection is certainly less. I won't know if I've solved it til I get some run time. Share this post Link to post Share on other sites
