WH1987 10 #1 Posted May 9, 2022 I have two 414-8 Wheel Horse Tractors. Both have HD reinforced spindles. I am looking for this type of spindle which the length is 5-1/4 long as opposed to a regular spindle is 4-1/4 long. Does anyone know where I can get these spindles ? Share this post Link to post Share on other sites
ri702bill 12,172 #2 Posted May 9, 2022 Welcome! I'll throw this out there - IF you cannot find those, consider doing the trailer stub axle modification with tapered roller bearings. Numerous folks here have done this, mostly for FEL applications, I believe @ebinmaine has already done this on his "ongoing" Colossus project. Just ask ... 1 Share this post Link to post Share on other sites
ebinmaine 79,034 #3 Posted May 9, 2022 3 minutes ago, ri702bill said: Welcome! I'll throw this out there - IF you cannot find those, consider doing the trailer stub axle modification with tapered roller bearings. Numerous folks here have done this, mostly for FEL applications, I believe @ebinmaine has already done this on his "ongoing" Colossus project. Just ask ... I was going to go that way with Colossus project, yes. But I went even bigger on that and had somebody make some custom spindles up for me. I do however still have the pieces I was going to use on that and they're going to end up on my 1974 c160 at least for the summer. Why are you looking for spindles? Do you have a worn one? A broken one? 1 Share this post Link to post Share on other sites
WH1987 10 #4 Posted May 9, 2022 9 minutes ago, ebinmaine said: I was going to go that way with Colossus project, yes. But I went even bigger on that and had somebody make some custom spindles up for me. I do however still have the pieces I was going to use on that and they're going to end up on my 1974 c160 at least for the summer. Why are you looking for spindles? Do you have a worn one? A broken one? My LH spindle is bent. 1 Share this post Link to post Share on other sites
Handy Don 16,698 #5 Posted May 9, 2022 (edited) 1 hour ago, WH1987 said: I have two 414-8 Wheel Horse Tractors. Both have HD reinforced spindles. I am looking for this type of spindle which the length is 5-1/4 long as opposed to a regular spindle is 4-1/4 long. Does anyone know where I can get these spindles ? Yes, welcome! I'm not sure what you are seeking exists. The longer spindles I've seen were 1" diameter on swept axle 520-H models and were set up for tapered wheel bearings. The HD spindles like the ones you have are the heaviest and longest ¾" axles I've seen. Edit: Re-reading, I'm not sure I understood your "length" dimension. Is that the dimension through the wheel or through the axle? Edited May 9, 2022 by Handy Don 1 Share this post Link to post Share on other sites
WH1987 10 #6 Posted May 9, 2022 4 minutes ago, Handy Don said: Yes, welcome! I'm not sure what you are seeking exists. The longer spindles I've seen were 1" diameter on swept axle 520-H models and were set up for tapered wheel bearings. The HD spindles like the ones you have are the heaviest and longest ¾" axles I've seen. Edit: Re-reading, I'm not sure I understood your "length" dimension. Is that the dimension through the wheel or through the axle? Through the wheel. 1 Share this post Link to post Share on other sites
WH1987 10 #7 Posted May 9, 2022 Just now, WH1987 said: Through the wheel. They are .750 diameter 1 Share this post Link to post Share on other sites
WH1987 10 #8 Posted May 9, 2022 This is what the spindle looks like. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,259 #9 Posted May 9, 2022 https://www.partstree.com/models/80490-toro-heavy-duty-wheels-spindles-kit-1983/parts-list-for-heavy-duty-front-wheels-and-spindles-kit-factory-order-number-8-0490-2/ 1 Share this post Link to post Share on other sites
Handy Don 16,698 #10 Posted May 9, 2022 (edited) 3 minutes ago, WH1987 said: This is what the spindle looks like. Yep. I'm sure others will chip in, but those are the strongest and longest ¾" spindles I've seen. Are you trying to simply replace the bent one or get longer ones? Edited May 9, 2022 by Handy Don 1 Share this post Link to post Share on other sites
WH1987 10 #11 Posted May 9, 2022 3 minutes ago, Handy Don said: Yep. I'm sure others will chip in, but those are the strongest and longest ¾" spindles I've seen. Are you trying to simply replace the bent one or get longer ones? I would like to replace if I can find one. Otherwise I will try and repair this one. I have two machines with these spindles. Both are 414-8 machines. 1 Share this post Link to post Share on other sites
Handy Don 16,698 #12 Posted May 9, 2022 Ah, my apologies at confusing myself and trying to confuse you. I would put a post in the Classified/Wanted section you'll find at the top of the page. Include the picture and specify the axle diameter and wheel side length for what you need. If someone needs more info they'll post or PM you. Please DO NOT put your phone number or other personal info in your post--rely on PMs via the Forum. 1 Share this post Link to post Share on other sites
WH1987 10 #13 Posted May 9, 2022 22 minutes ago, Handy Don said: Ah, my apologies at confusing myself and trying to confuse you. I would put a post in the Classified/Wanted section you'll find at the top of the page. Include the picture and specify the axle diameter and wheel side length for what you need. If someone needs more info they'll post or PM you. Please DO NOT put your phone number or other personal info in your post--rely on PMs via the Forum. I will try that later. I actually found the correct TORO p/n but it is no longer available. The assembly diagram shows the correct HD spindle. p/n 107651 for LH and p/n 107650 for RH. I will try and locate one but may have to repair the one I have. Thank you for your help. 3 Share this post Link to post Share on other sites
ri702bill 12,172 #14 Posted May 9, 2022 For what it's worth - judging by the severity of the damage to the spindle - you probably have other problems related to that. Bent rim, destroyed outer bearing, bent tie rod, on and on. What exactly happened?? Got a Honda 4313 Rider years ago where the PO missed the cup holder and pegged a tree. All the above as described... 1 1 Share this post Link to post Share on other sites
wallfish 20,002 #15 Posted May 9, 2022 I'm curious what happened to bend it like that. My loader tractor that has been worked to it's limits and beyond has those spindles on it and never bent one. 2 Share this post Link to post Share on other sites
WH1987 10 #16 Posted May 10, 2022 2 hours ago, ri702bill said: For what it's worth - judging by the severity of the damage to the spindle - you probably have other problems related to that. Bent rim, destroyed outer bearing, bent tie rod, on and on. What exactly happened?? Got a Honda 4313 Rider years ago where the PO missed the cup holder and pegged a tree. All the above as described... 1 hour ago, wallfish said: I'm curious what happened to bend it like that. My loader tractor that has been worked to it's limits and beyond has those spindles on it and never bent one. Interesting story but I do not drink while operating machinery. I have had this machine for 20 years and have not hit anything to do that. The RH spindle sheared at that joint about 5 years ago and I had it repaired. The LH is currently bent so before it shears I will repair it. My guess is seeing it is on the same machine it is a manufacturing issue which caused fatigue in the 90 degree bend. I have another 414-8 with a loader and so far no problem. 3 Share this post Link to post Share on other sites
wallfish 20,002 #17 Posted May 10, 2022 34 minutes ago, WH1987 said: Interesting story but I do not drink while operating machinery. I have had this machine for 20 years and have not hit anything to do that. The RH spindle sheared at that joint about 5 years ago and I had it repaired. The LH is currently bent so before it shears I will repair it. My guess is seeing it is on the same machine it is a manufacturing issue which caused fatigue in the 90 degree bend. I have another 414-8 with a loader and so far no problem. That is interesting ! Bending metal can cause fatigue as I was going to suggest just bending it back may result in the same problem. Wonder if the factory had to bend them after they were originally made???? 2 Share this post Link to post Share on other sites
mrc 1,084 #18 Posted May 10, 2022 hello WH1987, back in the day (15-20 years ago) the kit that wh sold had the two gusseted HD 3/4 inch spindles and two HD wheels. the wheels had a larger hub which held a larger bearing. similar to the standard 3/4 inch ID bearing only bigger OD. I bought the last kit my dealer had. the kit was $200. back then. hopefully someone has an extra. best of luck and welcome to redsquare mike in mass. 2 Share this post Link to post Share on other sites
