Dan.gerous 2,696 #1 Posted May 1, 2022 Evening/morning Just a quick one, does anyone have a photo of the way the battery in a C125 is secured? All 3 of mine are bodge jobs, wire, bailing twine and bungee. Did a search on here and a result came up from 2008 but the pictures are missing Thanks in advance 👍 Share this post Link to post Share on other sites
SylvanLakeWH 32,597 #2 Posted May 1, 2022 I use large black zip ties… Never seen a stock set up… 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #3 Posted May 2, 2022 https://www.partstree.com/models/01-12k801-c-125-toro-garden-tractor-1980/electrical-system-c-175-twin-cylinder-model-9/ 2 Share this post Link to post Share on other sites
tunahead72 2,662 #4 Posted May 2, 2022 You might get some ideas from this thread: 414-8 battery hold down - Wheel Horse Tractors - RedSquare Wheel Horse Forum Stens has a universal hold-down kit that includes the L-hooks, cross bar and wing nuts, pretty reasonably priced: 425-405 Battery Hold Down Kit (stens.com) 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #5 Posted May 2, 2022 Looks easy enough to fabricate something similar to the options above - thanks guys, as always! @SylvanLakeWH Zip ties would be fine, but be nicer to have something more technical 2 Share this post Link to post Share on other sites
ri702bill 13,087 #6 Posted May 2, 2022 22 minutes ago, Dan.gerous said: Zip ties would be fine, but be nicer to have something more technical Talking zip ties??? 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #7 Posted May 2, 2022 OK, so what is this, it's bolted in behind the battery and the brown plastic connection sparked then wheelhorse was dead.... Share this post Link to post Share on other sites
Dan.gerous 2,696 #8 Posted May 2, 2022 Was a bad earth that caused the spark. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #9 Posted May 2, 2022 Voltage regulator that is shown starting in 1982 ipl https://www.partstree.com/models/01-12k803-c-125-toro-garden-tractor-1982/electrical-system-single-cylinder-models-6/ 2 1 Share this post Link to post Share on other sites
peter lena 10,076 #10 Posted May 2, 2022 @Dan.gerous grounding is a major issue on horses , converted all mine over to a main line grounding set up . add another battery cable , from your battery ground bolt point , behind dash , to corner of engine / frame , next to clutch pedal , use serrated washers and dielectric grease , at every bolt point , from there , use 10-12 ga wire to engine charging rectifier area , and on to headlights . also run 10-12 ga wire directly back to behind dash / gauge area . that simple grounding enhancement , has eliminated erratic wire issues I had . if you have a single alligator clip heavy ga wire made up , you can easily verify this gain , with clip on . thats what I did . pete 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #11 Posted May 2, 2022 Have made a holder out of bits laying about the workshop. Cut some thread into the bar, fingers crossed that it works. Red paint reacted to the undercoat, but it's all I have at the moment. 3 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #12 Posted May 2, 2022 48 minutes ago, peter lena said: @Dan.gerous grounding is a major issue on horses , converted all mine over to a main line grounding set up . add another battery cable , from your battery ground bolt point , behind dash , to corner of engine / frame , next to clutch pedal , use serrated washers and dielectric grease , at every bolt point , from there , use 10-12 ga wire to engine charging rectifier area , and on to headlights . also run 10-12 ga wire directly back to behind dash / gauge area . that simple grounding enhancement , has eliminated erratic wire issues I had . if you have a single alligator clip heavy ga wire made up , you can easily verify this gain , with clip on . thats what I did . pete Yes they seem very touchy about earth's - does that cure misfires? Share this post Link to post Share on other sites
pfrederi 21,172 #13 Posted May 2, 2022 (edited) 3 minutes ago, Dan.gerous said: Yes they seem very touchy about earth's - does that cure misfires? You can trust your Mother but never your ground (earth) Edited May 2, 2022 by pfrederi 2 Share this post Link to post Share on other sites
Dan.gerous 2,696 #14 Posted May 2, 2022 It's on, had to tweak it a bit but it's very secure 4 3 Share this post Link to post Share on other sites
Dan.gerous 2,696 #15 Posted May 2, 2022 25 minutes ago, pfrederi said: You can trust your Mother but never your ground (earth) Fantastic advice!! Share this post Link to post Share on other sites
Dan.gerous 2,696 #16 Posted May 2, 2022 1 hour ago, gwest_ca said: Voltage regulator that is shown starting in 1982 ipl https://www.partstree.com/models/01-12k803-c-125-toro-garden-tractor-1982/electrical-system-single-cylinder-models-6/ All three of the regulators on the C125's look rough. Is there a modern replacement? Share this post Link to post Share on other sites
peter lena 10,076 #17 Posted May 2, 2022 @Dan.gerous so the tweaking helped ? notice a lot of your wiring connections are replacement make up ends .ever add a separate ground to your dash area ? the collective different metal types , are very prone to corrosion , often giving your wringing a poor connection . would bet a lot of your issue is poor conductivity at the dash area .your strongest start point is your battery ground cable bolt down point . bolt this type of connection to that bolt ,https://www.bing.com/images/search?view=detailV2&ccid=Q%2fxbTfrI&id=1940B4AF359A54DA0B7B6F47883936A9F9A03AFC&thid for a easy go to secure ground point . your local h/w store should have them in the contractor electrical section . only a suggestion , pete 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #18 Posted May 2, 2022 38 minutes ago, peter lena said: @Dan.gerous so the tweaking helped ? notice a lot of your wiring connections are replacement make up ends .ever add a separate ground to your dash area ? the collective different metal types , are very prone to corrosion , often giving your wringing a poor connection . would bet a lot of your issue is poor conductivity at the dash area .your strongest start point is your battery ground cable bolt down point . bolt this type of connection to that bolt ,https://www.bing.com/images/search?view=detailV2&ccid=Q%2fxbTfrI&id=1940B4AF359A54DA0B7B6F47883936A9F9A03AFC&thid for a easy go to secure ground point . your local h/w store should have them in the contractor electrical section . only a suggestion , pete I still have a bad earth as its clicking rather than turning over, but havent got any wire on site so will go into town in the morning and implement your changes - might be more questions tomorrow! Its such a huge help as I am an amateur at this stuff, and hate having machines not working properly. I did wonder about the earth as it goes to the aluminum section of the dash, surely leading it directly to the chassis would be better anyway. I also see what you mean about the wires, I haven't touched this machine since buying it two years ago, the original owner has quite a few "adjustments" on it. The machine sat next to it is in a similar state, but will work on one at a time! 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #19 Posted May 2, 2022 43 minutes ago, peter lena said: @Dan.gerous so the tweaking helped ? notice a lot of your wiring connections are replacement make up ends .ever add a separate ground to your dash area ? the collective different metal types , are very prone to corrosion , often giving your wringing a poor connection . would bet a lot of your issue is poor conductivity at the dash area .your strongest start point is your battery ground cable bolt down point . bolt this type of connection to that bolt ,https://www.bing.com/images/search?view=detailV2&ccid=Q%2fxbTfrI&id=1940B4AF359A54DA0B7B6F47883936A9F9A03AFC&thid for a easy go to secure ground point . your local h/w store should have them in the contractor electrical section . only a suggestion , pete Forgot to ask, how do you add a separate ground to the dash? Share this post Link to post Share on other sites
WHX?? 58,209 #20 Posted May 2, 2022 Lots of threads here Dan on that regulator ...which actually is not a regulator at all but merely a rectifier. Very prone to over charging battery with extended seat time. They are very expensive over here these days and hen's teeth over there most likely. The general consensus is to replace it wit a cheaper and available three term regulator. Do a search here on 109313 and you'll find some good poop on replacing it. 3 1 Share this post Link to post Share on other sites
roadapples 6,987 #21 Posted May 2, 2022 Clean all ground points with wire brush and coat with dielectric grease. No more problems... 2 Share this post Link to post Share on other sites
peter lena 10,076 #22 Posted May 2, 2022 @ Dan.gerous , that separate ground is easy , go from your battery ground bolt point , to the dash area , then you can single wire to all of your gage mounts , bolt , bracket points . that dash dissimilar metal is the ground culprit , when I did that to mine , issues stopped . the bolt on electrical luge info I sent you is a very simple / easy electrical connection . pete 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #23 Posted May 2, 2022 1 minute ago, peter lena said: @ Dan.gerous , that separate ground is easy , go from your battery ground bolt point , to the dash area , then you can single wire to all of your gage mounts , bolt , bracket points . that dash dissimilar metal is the ground culprit , when I did that to mine , issues stopped . the bolt on electrical luge info I sent you is a very simple / easy electrical connection . pete Will start on that tomorrow, should be able to find most of the bits in town. The Lug is proving difficult, but it's probably called something else over here. 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #24 Posted May 2, 2022 7 hours ago, Dan.gerous said: Looks easy enough to fabricate something similar to the options above - thanks guys, as always! Do... you actually have a battery holder like this? I have that one for auction on ebay... Don Share this post Link to post Share on other sites
Dan.gerous 2,696 #25 Posted May 2, 2022 1 minute ago, Snoopy11 said: Do... you actually have a battery holder like this? I have that one for auction on ebay... Don Mine have a plastic bottom, but the batteries are too big for the platform anyway. The new holder is pretty good so will probably build two more for the other horses. Share this post Link to post Share on other sites
