rick 321 #1 Posted July 1, 2009 Hi- The gas spring that holds the seat in the raised position on my '89 310-8 has given up the ghost. Matching measurements for a new one is no problem, but knowing the proper spring rate is, since whatever numbers that may have been present on the original are gone...Has anyone found a less expensive ($43.78 list) replacement? I really would like to do away with the piece of scrap metal I am using now to hold up the seat when I refuel and put the seat up when I am done (to keep the cat from off). BTW, the 37" SD deck works very well, even with the baffle underneath worn/rusted away! Share this post Link to post Share on other sites
TJ 184 #2 Posted July 1, 2009 I bought one at Auto Zone for around $12.00 three years ago. I just matched up the length, and drilled the mounting holes a little larger. Good luck Tom Share this post Link to post Share on other sites
dgjks6 8 #3 Posted July 1, 2009 Mine also quit working years ago. I solved the problem years ago with a loud yell for Ali, Michael, Megan, Abbey, Katie, or Nicole. Then one of them runs out and holds the seat up while I put gas in. Share this post Link to post Share on other sites
rick 321 #4 Posted July 2, 2009 Thanks for the tips....although I would have to holler loud for children or grandchildren, they are from 1/4 mile to two miles away! Share this post Link to post Share on other sites
Raider12 14 #5 Posted July 2, 2009 I solved the problem years ago with a loud yell for Ali, Michael, Megan, Abbey, Katie, or Nicole. Then one of them runs out and holds the seat up while I put gas in. They have to earn their keep some how........ right? Share this post Link to post Share on other sites
JoeMonag 1 #6 Posted July 4, 2009 Rick, at the suggestion of another member. I bought a "gas spring" at Advance Autio parts, that was about the same size for around $10.00 I had to open up the eye-let holes to fit over the wheel horse spacers. It took a little time to drill them out, as the eye-let ends are stainless or some type of harden material. I just kept re-sharpening my drill bits on my "Drill Doctor", and eventually opened the hole up to somthing around .375" I did it during the winter. I use my 310-8 to plow my 400 foot drive way, I usually top off the tank, when I finish plowing,to be ready for the next storm, and it was making me crazy when the gas spring stopped working. The 10 dollar gas spring works fine on my working tractor and has relieved the frustration of re fueling. Good luck Joe in Norton Share this post Link to post Share on other sites
Kelly 1,038 #7 Posted July 4, 2009 Can someone tell me how long open the shock is? I'd like to install one on my older tractor to hold the seat up for filling the tank. maybe a pic on how the factory mounted them. Share this post Link to post Share on other sites
TJ 184 #8 Posted July 4, 2009 Kelly: The gas spring is approx. 10 inches long on center from mounting holes. Tom Share this post Link to post Share on other sites
rick 321 #9 Posted July 5, 2009 Do the replacements from AA seem to have the correct force to hold the seat up without undue stress? The reason I ask is that I tried the gas spring from the trunk of a Chevy Impala (same Size), but it was much too powerful for the task at hand and never tried it. I had visions of sheet metal distortion, etc. Share this post Link to post Share on other sites
TJ 184 #10 Posted July 5, 2009 The one on bought has more psi than the original equipment, but other than being a little harder to push the seat down, I haven't had any problems. Hope that helps. Share this post Link to post Share on other sites
truckin88 104 #12 Posted July 6, 2009 I just bought the oem replacement from parts tree, about $30.00 if it does not last more than 3 years I will be doing autozone. Share this post Link to post Share on other sites
WheelHorse_of_course 101 #13 Posted July 6, 2009 If you can match things up Surplus Center has a few at good prices: http://www.surpluscenter.com/sort.asp?UID=...sc&keyword=XG11 :thumbs2: Share this post Link to post Share on other sites
300zx 7 #14 Posted November 1, 2010 This is a good generic replacement for the seat strut (gas spring). I found it at Advance, StongArm F4673 (center one in the picture below). It was $11.99, but if you buy two with the current sale flyer, they reduce them $2.50 each, so the final cost before tax was $9.49. It has the same 3 inch stroke, 9.5 inch center to center length and 3/8 inch holes at each end as the OEM. The shaft and gas chamber are a little smaller in diameter than the OEM. Closing force is about 35 lbs. I put it on this morning and it worked perfectly. Since I needed 4, it was a good savings over the $40 OEM gas spring. Does anyone know the closing force on a new OEM gas spring? 35 lbs on this one seems to work well with the seat. Share this post Link to post Share on other sites
