Wheeliehorseman 0 #1 Posted April 16, 2022 (edited) I am trying to find the OEM front pulley size also what is the best way to unlock a rear end, it won't shift it has been sitting for awhile Edited April 16, 2022 by Wheeliehorseman Share this post Link to post Share on other sites
953 nut 64,275 #2 Posted April 16, 2022 9 hours ago, Wheeliehorseman said: what is the best way to unlock a rear end, it won't shift it has been sitting for awhile Since your Wheel Horse has been sitting long enough to have the shift rails rust in place there is probably a lot of other issues to be dealt with in there. Drain the fluid (drain plug is near the back and requires a 1/4" Allen Wrench) and remove the transmission so it can be opened up. This thread from @stevasaurus will guide you through the process and if you need information along the way that is what we are here for. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #3 Posted April 16, 2022 12 hours ago, Wheeliehorseman said: I am trying to find the OEM front pulley size Gear transmissions with 1-1/8" crankshaft use 4" OD engine pulley #7466. 2 Share this post Link to post Share on other sites
Wheeliehorseman 0 #4 Posted April 20, 2022 On 4/16/2022 at 6:39 AM, 953 nut said: Since your Wheel Horse has been sitting long enough to have the shift rails rust in place there is probably a lot of other issues to be dealt with in there. Drain the fluid (drain plug is near the back and requires a 1/4" Allen Wrench) and remove the transmission so it can be opened up. This thread from @stevasaurus will guide you through the process and if you need information along the way that is what we are here for. Thank you I will check it out Share this post Link to post Share on other sites
