Similar Content
By Wheel Horse Willy
Hey all!
New to the page so first, thank you for the add! I’ve been a Wheel Horse fan for over 20 years since my old neighbor and his grandfather got me hooked! After many years of searching, I finally got a hold of a real one! I did have a Toro-Wheel Horse….212-? It was a good machine but gave it to a friend for a back up. I picked up a 1988 , 252-H and it’s clean! A little rust but the red shines up nice! Everything is original. Belts, tires, bulbs….fuel line and filter have been replaced. I started cutting my lawn the day I brought it home and since my yard is a little hilly, thought maybe the sensor under the seat was the culprit for the stall but it seems to depend how warm it is out? I managed to cut the entire back yard today and just as I was pulling it into the shed, it sputtered and died. It fires right up and runs great when cold! Even seems fine after a while running but after reading a few posts, I might try to replace the spark plug. The one thing I did not check. This was an issue with a 20+ year old Echo weed wacker I had so I will try that. If anyone has any other ideas/info, I would appreciate it! Thank you and have a great evening!
By MachXXII
I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
By indywheelhorsenut
Started fine 2 weeks ago. I left key in ignition and fear grandson may have turned it slightly to right a week ago.. not enough to engage starter but perhaps enough to drain battery.
Went to start it yesterday and no charge at all. Started charging it and battery began to take charge. However starter turned over but didnt turn engine over.
Question is do I just need more of a charge (more amps) or do I have another problem?
Lol, have 5 inches of snow headed here starting tonight so I need to get ahead of this today.
By mmmmmdonuts
My cheap-o walmart U1 battery is starting to bite the dust again (barely able to crank it over fully charged, and ozzing everywhere) after 3 years on my 68' Raider and I am looking into a new battery for winter as I now have a plow setup. I was thinking of either getting the original 22NF battery that came with it or running a mazda mita battery which is a U1 size. Is the AGM worth the extra money over the 22nF even in the smaller size? I think the vibrations keep killing the cheapo batteries and I am trying to make sure I can leave it out in the cold and not have a problem starting in the winter. It does get down to 0F or below zero every once in a while. I don't think I want to go all the way to a 22nF AGM as it is $200.
Thoughts?
