ebinmaine
1986 417A wiring and starting help needed
ebinmaine
@JCM here's tractor #2...
I'd like to get this beast up n runnin' and drive it so I can see if the transmission is healthy.
After that I may borrow the engine for a bit for another tractor.
The PO had a nephew that had good intentions but some folks just should not pick up a tool.
The wiring is partially removed from the tractor.
There is no test circuit board.
There are no test lights.
Here's the schematic diagram I've been using.
The engine topside has a GREEN wire coming out where I believe it should have a BLUE wire for the (oil pressure sensor??).
I have to assume it's a replacement wire and/or sensor.
At the plug where that wire would normally lead into and exit there is NO wire on the outgoing side as it's been cut.
Note the end of the screwdriver.
Do I need the oil pressure sensor to be connected to start the engine?
If so what do I connect that green wire to?
Thanks.
  • Sad 1
Handy Don
If you have the right schematic, then the oil switch is an indicator light only. Only the seat and PTO safeties affect start/run.
ebinmaine
I believe the schematic is a colorized version of the OE Wheelhorse diagram so it should be right.
That info makes sense. I'll do more when I get time.
Those safety switches are temporarily bypass-able so it should be headed towards starting with a coil, 2 plugs, and 2 ignition wires.
  • Like 5
953 nut
10 hours ago, ebinmaine said:
get this beast up n runnin' and drive it so I can see if the transmission is healthy.   If your only goal is to get the engine running to test the engine and transmission then the only wiring you'll need is a temporary jumper wire from the battery "+" (switch optional) to the ignition coil "+" terminal and a small jumper wire from the battery side of the solenoid to the small blue wire on the solenoid for momentary contact (push button optional).
Do I need the oil pressure sensor to be connected to start the engine?   NO, a test light to reassure you that there is oil pressure might be nice though.
Edited by 953 nut
  • Excellent 2
ebinmaine
I wondered if that was a possibility. Thanks Richard.
pacer
Dont remember the model I had, but it hat that .... long! row of idiot lights and as I started fooling with it I pretty quickly could see that to get that mess back would take hours and prolly would still not be back right. And like you, I needed to see the thing run in order determine if it was even worth continuing. So, I ripped all that tangle out and reset it up with a simple on/off/run. Once I did that - which of course is simple - I had it running quickly ----- and, the best part was that every thing was AOK, and turned out to be a nice tractor.:thumbs2:
