Fishroe 261 #1 Posted April 7, 2022 (edited) Only local place I could find now is Napa $15.49 Tractor Supply, Advance Auto don’t have them on their website. Has screw and spade terminals Edit. agri has it with the rubber housing Edited April 7, 2022 by Fishroe Share this post Link to post Share on other sites
peter lena 9,517 #2 Posted April 7, 2022 @Fishroe walmart might have them , got mine on line , with spade terminals , also a good time to , increase grounding , on your unit , if you want to . a simple test upgrade , small alligator clip wire from battery ground bolt to dash area , to headlight grounding , notice the difference ? pete Share this post Link to post Share on other sites
lynnmor 8,150 #3 Posted April 7, 2022 It might be a good time to replace with PAR 36 LED lamps. 3 4 Share this post Link to post Share on other sites
peter lena 9,517 #4 Posted April 7, 2022 @lynnmor thats what I got , LED,S, terrific lighting with almost nothing amp draw. pete 1 Share this post Link to post Share on other sites
squonk 44,751 #5 Posted April 7, 2022 Quite often Napa and other stores will have that light with the rubber housing cheaper than the bulb itself. Remove the bulb and throw the housing away. 2 Share this post Link to post Share on other sites
Lost Pup 173 #6 Posted April 7, 2022 https://shop.advanceautoparts.com/p/sylvania-4411-basic-sealed-beam-bulb-box-of-1-4411 Advance auto at 14.99. Share this post Link to post Share on other sites
Fishroe 261 #7 Posted April 7, 2022 I know a lot of you like the LEDs but I’m not a big fan of them I still use them every lightbulb in my house now is LED i’ve had to replace three of them in the last two years I don’t think they last any longer than incandescent bulbs but the government says I can’t use incandescent anymore One or two dollars apiece I guess I’m still living in the 70s and 80s I guess i used the wrong search words on Advance website. I put in 4411 headlights all I got was headlight bulbs for cars Share this post Link to post Share on other sites
Lost Pup 173 #8 Posted April 7, 2022 I call it “unicorn” shopping. Many websites today have great products if you will just hidden away. I usually search and post here to find items, best resource available. Share this post Link to post Share on other sites
