Similar Content
By BuffaloD200
Finally getting around to working on my ark loader. The previous owner said he thinks the problem is with the spool valve.
As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
I noticed the power beyond port is connected to the reservoir return. Is that right?
Anyone see anything blatantly incorrect?
By 1126chbell
I'm looking to see if anyone knows of a diagram or video on how to hook up the deck linkages on a d250 friends got it from bought it at auction and deck was already off
By Titus105
I have a D250, always wanted one and as usual the steering box needs replaced. Now I could just find a new used one, but I seen it mentioned that the power steering from a JD 318 would work to replace the steering box.
Has anyone tried this swap. And if so, do you have any pictures.
By B J
Nice 520H with 60 inch deck, 44 inch snowblower, winter cab, 42 inch blade although the tractor has the brackets on the back axle the blade doesn't have the extension. Also have the deflector for the mower discharge and a set of tire chains that may fit the tractor. 735 hours. Please text for more pictures
By Ironman
Could someone please tell me the size of the front/mid pto belts for the D250? I'm having a heck of a time trying to match one up. Thanks
