Wheelhorse#1 1,998 #1 Posted March 25, 2022 All. I have 73 B80 It’s missing the mule drive and the plates on the side of the Frame that hold the deck(not sure of the name of them, one on each side. My question is can I use the mule drive and attach o matic parts from a 1974 Auto no name and mount the 05-36MR01 deck to the 74 B80 ? Pic is of the deck I want to use on the B80 Share this post Link to post Share on other sites
Ed Kennell 47,597 #2 Posted March 25, 2022 I assume you have the front attach-a-matic to mount the mule drive. The mid attach-a-matic from the '73 should work on the '74. Worse case you would have to drill new holes in the frame to move the deck forward to clear the rear wheels. Share this post Link to post Share on other sites
Wheelhorse#1 1,998 #3 Posted March 25, 2022 (edited) 10 hours ago, Ed Kennell said: I assume you have the front attach-a-matic to mount the mule drive. The mid attach-a-matic from the '73 should work on the '74. Worse case you would have to drill new holes in the frame to move the deck forward to clear the rear wheels. Yes Sir Everything is there on the 73 auto.The PO used it mainly to cut grass Edited March 26, 2022 by Wheelhorse#1 Share this post Link to post Share on other sites
