Racinbob 13,040 #1 Posted March 25, 2022 I've been using sealed front axle bearings for my non-workers for some time now to avoid the grease mess. About 3 years ago I switched my workers to sealed and it's working out very well. The 854 I purchased at the 2018 big show still had the regular sealed on one side only. I was given a pair of 23-8.50's for it and the past few days I got them repainted and ready to go on. Then I decided to pull the fronts and repaint them as well as replace the bearings to fully sealed. My bearing stash was depleted so I looked for more and came across these. They are promoted as lasting 'twice as long' as standard bearings. Note the steel seals. I had never seen these before so I decided to give them a shot. The 854 with the sickle mower won't get the mileage as the other workers so I suspect they will be just fine. 4 2 Share this post Link to post Share on other sites
squonk 47,381 #2 Posted March 25, 2022 They should work well Bob. We ain't runnin the Indy 500 with these tractors. 5 Share this post Link to post Share on other sites
WHX?? 57,388 #3 Posted March 25, 2022 (edited) We were just yakin about this in another thread. @RichJ wanted to know about the early bushing style and @oliver2-44 turned him on to the wheel barrow style we all use. Those look to be what's called precision bearings whereas the the wheel barrow styles are... well .... ya never know how sloppy they are gonna be 'till you open the box. Low speed only which is fine I guess for what we do. I found the high speed ones in 1 1/38x3/4x flanged once but CRS where. Got a source Bob? How did they fit in the hubs....goodentite? Edited March 25, 2022 by WHX?? Share this post Link to post Share on other sites
Racinbob 13,040 #4 Posted March 25, 2022 1 hour ago, WHX?? said: We were just yakin about this in another thread. @RichJ wanted to know about the early bushing style and @oliver2-44 turned him on to the wheel barrow style we all use. Those look to be what's called precision bearings whereas the the wheel barrow styles are... well .... ya never know how sloppy they are gonna be 'till you open the box. Low speed only which is fine I guess for what we do. I found the high speed ones in 1 1/38x3/4x flanged once but CRS where. Got a source Bob? How did they fit in the hubs....goodentite? Sent a PM Jim. ye, I say the fit is just right. I'll just have to tap them snug. 1 Share this post Link to post Share on other sites
Racinbob 13,040 #5 Posted March 25, 2022 2 hours ago, squonk said: They should work well Bob. We ain't runnin the Indy 500 with these tractors. Ya just burst my bubble Mike. I had plans.................... 3 Share this post Link to post Share on other sites
JoeM 10,093 #6 Posted March 25, 2022 the last outer PTO bearing I changed had those steel seals. They seemed pretty smooth to me. Share this post Link to post Share on other sites
lynnmor 8,898 #7 Posted March 25, 2022 Rubber seals protect from water and dust better than the steel shields. You make your choice depending on the conditions, for example if you wash your tractor the steel shields may not be for you. Share this post Link to post Share on other sites
pfrederi 20,869 #8 Posted March 26, 2022 19 hours ago, lynnmor said: Rubber seals protect from water and dust better than the steel shields. You make your choice depending on the conditions, for example if you wash your tractor the steel shields may not be for you. \ Guess i can order steel seals. I keep my horses out the water. Once and great while i may use a bit to rinse the dust off the hoods. Share this post Link to post Share on other sites
Racinbob 13,040 #9 Posted March 26, 2022 1 hour ago, pfrederi said: \ Guess i can order steel seals. I keep my horses out the water. Once and great while i may use a bit to rinse the dust off the hoods. In any case I'm sure you'll be fine. I'm sure they keep contaminates, including water, out as well as any. Share this post Link to post Share on other sites
Lane Ranger 12,031 #10 Posted March 26, 2022 Just keep running them until the wheels fall off! 2 Share this post Link to post Share on other sites
pacer 3,180 #11 Posted March 27, 2022 On 3/25/2022 at 10:04 AM, Racinbob said: using sealed front axle bearings for my non-workers for some time now to avoid the grease mess Now theres a guy after my own ... thinking! Not to long after I got bit by the WH 'bug' and had removed 2-3-4 of the front wheels and saw that .... awful MESS of globbed up, hardened, nasty grease, I say to meself - there must be a better way!! And sure enough I changed to the sealed bearings .... well, a long time ago. And off hand I cant recall ever replacing one. Soooo much nicer!! I still use the sealed ones, I'm on my second batch of 10 pieces off the bay for $20/25ish I think, and no, they are not top line bearings, but as already mentioned, we arent running the Indy 500 and have served me fine. I will add though that last time I looked I had quite a search for the flanged type - another reason to get 10 at a time. 2 Share this post Link to post Share on other sites
