41chevy 74 #1 Posted March 25, 2022 Do you put anything on the trans case gasket, light coat of gasket maker or Indian head or just dry? 1 Share this post Link to post Share on other sites
ebinmaine 75,733 #2 Posted March 25, 2022 Just now, 41chevy said: Do you put anything on the trans case gasket, light coat of gasket maker or Indian head or just dry? @stevasaurus Not sure what the other fine folks do but I put mine on dry. I figure the transmission case is quite stiff and not much prone to flexing. Plenty of bolts to hold it all together. 2 Share this post Link to post Share on other sites
daveoman1966 3,880 #3 Posted March 25, 2022 I've never has to use any gasket cement... just put the gasket on dry. Your discretion though... 3 Share this post Link to post Share on other sites
stevasaurus 23,515 #4 Posted March 25, 2022 The factory never used sealant, and neither do I. Just make sure it is clean and smooth, you will thank yourself if you have to ever take it apart again. 2 Share this post Link to post Share on other sites
WHX?? 53,313 #5 Posted March 25, 2022 I do ..a small amount, I had the last two leaked without it. 2 Share this post Link to post Share on other sites
Achto 30,189 #6 Posted March 25, 2022 I use a thin coat of gasket sealer on mine. it's a PITA to get back off if you need to open them back up again, but a Scotchbrite wheel on a 90 degree die grinder makes short work of it. https://www.amazon.com/Permatex-80015-Form-Gasket-Sealant/dp/B0002UEOU0/ref=zg_bs_15719581_21/144-4897151-0344826?pd_rd_i=B071QWMQM2&psc=1 2 Share this post Link to post Share on other sites
WHX?? 53,313 #7 Posted March 25, 2022 4 minutes ago, Achto said: I use a thin coat of gasket sealer on mine. Caught in the act..... 'Side do it right and it won't have to come apart for another 50 years..... I'll be dead.... 4 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #8 Posted March 25, 2022 At toro the gaskets still come with the inner part. I keep it to make other gaskets in the future. 2 Share this post Link to post Share on other sites
41chevy 74 #9 Posted March 25, 2022 3 hours ago, Maxwell-8 said: At toro the gaskets still come with the inner part. I keep it to make other gaskets in the future. 👍 Share this post Link to post Share on other sites
ebinmaine 75,733 #10 Posted March 25, 2022 4 hours ago, Maxwell-8 said: At toro the gaskets still come with the inner part. I keep it to make other gaskets in the future. Yepp. Same here. 2 Share this post Link to post Share on other sites
